Bluetooth doesn't upload contact address?
I just had bluetooth activated. I was disappointed to notice that a contact address doesn't display. i.e. Not able to use the contact address in NAV.
Is there a way to upload address books?
Also, say I'm in the iDrive screen area of Entertainment.. If you press the steering phone button, this automatically calls, I guess, the last number dialed. I would expect it to switch the screen to contact listings so I'm able to select a contact and call. ?
You may have to pair the phone and then send the contacts over as business cards, this seems to be especially true of the later Nokias whose bluetooth protocols seem to be flakey!
Oh! and if that is the case you will need to send them in blocks for example A-C D-F etc etc.
My Ride: 05 530I
I have an Iphone 3G, I just paired my phone and it automatically shows my address book after I pair it. Make sure your bluetooth on your Iphone is on before you start the pairing process, after that go on your menu and look for pair phone under the communication part. Tell us how it goes, hope it helps.
