Hello, I have a bmw e60 530i 2005 I wanna pair my blackberry 9800 torch with the car and have the calls from the car, I paired it with my car but nothing happened just pairing successfull and I can see my phone's name on the screen but I can't have my calls thru the car, I have the phone that comes with the car the motorola but I don't know how to use it, I would appreciate any help.
98 views and no replies seems nobody has any idea
i never used my bluetooth in the car. i figured id see if mine would work. it paired fine but when i went to enter a passcode i have no clue what it is and i tried 0000 but it looks like it takes more numbers then that. no clue . o well
Try deleting all previous pairings on the car and try again, MANY times that solves all the problems! :geek: Good Luck!
I have been able to successfully pair my BlackBerry Torch with my VM-605.
I would start by removing and reinserting your battery on your BlackBerry Torch. Then hold down the button on your VM-605 until you hear the words "Pairing Mode." On your Torch go to Options - Networks and Connections - Bluetooth Connections and verify Bluetooth is on. Press your menu key and select "Add device" (make sure you do this within a few minutes of enabling pairing mode on the VM-605) It should bring up the VM-605 and allow you to pair and create the profile. |
Thanks guys for helping
Still didn't find a way to work it out. |
