Blackberry Pearl 8100 pairing problems
Hi Folks, I don't know what some of you guys are doing right, but I'm having trouble pairing my new Pearl 8100 with my 2007 BMW 550i. I love both, so I really want to figure this one out.
I've got over 1000+ numbers stored on the Blackberry 8100 Pearl, T-Mobile edition. When I pair the device, it connects. Then after about ten seconds, it disconnects. I can get it to automatically reconnect, but it still disconnects after about 10 seconds. Very annoying!
I had a similar problem with my old phone, a Treo 650 from Verizon Wireless. At first, I had trouble pairing with the beamer. I had to remove extra digits after pauses in the speed dial numbers. Once I removed those extra digits, the problem went away.
Does anyone have any suggestions?
My Ride: G30 M550i
Model Year: 2018
Not sure what to tell you at this point. If the Pearl transfers all those numbers, maybe there's an issue with how many numbers can be transferred?
One more thing, did you see the following thread?:
http://forums.e60.net/index.php?showtopic=31493
Originally Posted by Rudy' post='341560' date='Oct 4 2006, 06:31 AM
Are you able to back-up the Pearl's contacts to a PC then delete them from the phone to see if it stays connected with an empty address book?
So, it looks like the components are working fine. My question would be, now, how do I get my regular numbers back into the phone without the bluetooth failing? Perhaps the bmw simply cannot handle 1000+ numbers.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by beamerlover' post='341667' date='Oct 4 2006, 03:50 PM
Excellent idea Rudy. The phone did not disconnect, and I was able to use my bluetooth Pearl. I tried manually adding another number to my address book, and it worked fine. Then I added non-numerical entries. Although it did not dial those numbers, the phone worked fine for the real numbers.
Originally Posted by Rudy' post='341789' date='Oct 4 2006, 07:36 PM
I don't use a Blackberry so I'm not familiar with the PC interface to be able to give you advice on loading some of the numbers, etc. It's very possible that the car has a memory limit beyond whatever it is that the Pearl is trying to send it. I think you may be the first to hit the limit but something tells me you won't be the last...
I've just linked my Pearl . . . about 200 contacts . . . connects and downloads addresses without a problem (and I do have nav). It's pretty impressive, too. Picks up work, home and mobile numbers, but knows not to download fax numbers. Very cool.
btw, this is a great device. Probably the best executed PDA/mobile on the market.
I'm not sure if this applies to the rest of your phone/idrive combinations.
In my case, after installing the Hong Kong OS on my 7100, i was able to upload my contacts, but limited to 500 actual numbers. I had to archive all the fax numbers and unessential contacts to reduce my list of 2000 plus.
i'm also considering upgrading to the pearl, but not sure if it works with their enterprise server solution.
hope this helps.
hope this helps.
My Ride: G30 M550i
Model Year: 2018
hope this helps.
hope this helps.
http://www.blackberry.com/products/blackbe...nterprise.shtml
