Better Bluetooth Streaming
#181
Administrator
And I note in your pic you don't have the red/white RCA plugs going into left/right channels of the Sure board...perhaps b/c you have my setup...no Aux 'board' that the plugs wld be soldered to (Aux board)?? So w/no Aux board it's just the one connection frm Aux cable to Sure middle jack?? I did note one of your pics has the white headphone jack in middle and a black plug connected to the side jack(of Sure board)...not sure what that's about/for.
Then, the cig lighter connection (power): I don't fully grasp this yet. I believe a wire is tapped or spliced to go to Sure board (soldered somewhere on board). I wld like to have the option of listening to music with car off though...which might require another power source frm my limited understanding.
To listen to Bluetooth with the car off, you'll need to find a fuse that stays active with the ignition off and tap into that. Just be careful because you'll open yourself to a whole host of battery drain problems if somehow you draw power for an extended period of time.
Thanks for walking me through this. I didn't want to order board before fully understanding - nothing worse than going in and missing something then having to put things back together unfinished! I think I'm ready to order the board now!
#182
My Ride: 13 X5 35i M-Sport (Sold) 535i M-Sport - (Sold) 07 530i Sport Gray - (Traded) 04 530i Sport Gray
No, I have the AUX connection in front of the rear seats just like the pictures show. I just opted not to use the RCA connection; I'm using the 3.5 mm headphone jack instead. You pick one or the other.
There is a female "barrel" connector on the board that you can use to supply the power. I felt that was more safe than trying to solder directly onto the board. I had a spare power supply from some other electronic device that I sacrificed the male connector for to tap into the cigarette lighter leads.
I do see the "VCC" and "GND" areas on the board now...I believe this is power. Solder to the board via the cig lighter is what I've seen...I don't believe no one ever simply states: "solder your black side cable to the GND area or the white/black side cable to the VCC area of the Sure Board". Or red/black cables etc. I don't know which way they actually go. My point is I guess this is why this post is still getting questions!! loll
I understand completely! I had issues comprehending how the connections are made too. I finally had a friend who's an electrical engineer help me put it all together.
#183
HOW to have BOTH??? Keep Aux -- add BT Module
Now that I have all my parts in place and ready to install, what is needed or what is the process for keeping the Aux input - and adding Bluetooth?? I see Roskinc has a BT Kit that he sells that allows this but after looking at the install video and scouring forums, I can't figure out what and or how.
#184
Assuming your going to install the BT board at the back of the center console where your aux input is that is real easy as well as shown in previous pics, just connect the the BT output wires at tha back of the aux socket, preferably soldered.
#185
1.) My 04 530i (10/2003 Build) Sport didn't have Aux in back. I purchased Roskinc Aux cable kit which is installed up front 2yrs ago.
2.) I just purchased the Sure BT Board and was prepping to install using the Aux port/cable/jack that I installed up front. I've read all 19pgs of this post several times as well as youtube clips and NOW understand how to install it using my Aux port.
3.) My post question is how to keep my non OEM Aux and add BT.
Unfortunately, I only learned after purchasing everything that Roskinc also has an adapter allowing for both (Aux and BT). So already having all the parts, I can't be too far off from the end goal....I just haven't been able to find info on the net or forums on how to keep them both - when they're NON OEM installed. I have also reached out to ask Roskinc but no response yet. Thx.
#186
Administrator
All you need to do is tap into the two leads from the wires that run to your OEM aux to the Sure board. What you should know, though, is that it's not a good idea to use both because whatever device you plug in could blow the board. It's not expecting an amplified signal.
#187
#188
Administrator
I too, disconnected the aux port at the recommendation of my electrical engineer friend. With Bluetooth built into almost every audio device these days, I can't see the future need for it. I decried losing the cassette player in my E39, but I can't remember the last time I played one.
#189
My suggestion in that case would,be to install a switch in the power circuit of the BT board and turn it off when you want to use the aux from another input, I for myself did not even install the aux socket as I could not see the need for it once you start using Bluetooth ......
Roskinc.com has the answer on his product page but outside of his pkg kit, it's not clear what's all involved. If the dual option is in the type of board, I just need to know and decide if I want to keep or return this one and get the dual option board/kit etc....yes, it is already sounding overly complicated! lol
#190
Bluetooth Adapter Installed!!!
So I finally decided to do this mod. I had previously ordered everything but it all sat on counter b/c I was fearful of getting in and not having something or other options if the main "simple" (so it appears) option failed. I went to auto stores seeing if I could buy a clean fuse tap - and guidance "where" to plug it - but both where blah, blah, blah.
Anyways...I am going back to Aux cable b/c 1) it has a muffled sound - Mine is NOT as crystal clear as everyone else claims. The Aux cable IS crystal clear...or normal I would say. 2) It does NOT Pair easy. 3) It does NOT pair more than one device at a time..i.e. My Note 4 and my wife's IPhone 6.
Pairing: I have to go through a whole exercise of car switched on, to car fully started. Turning off Bluetooth on my Note 4 to allow it to rescan. Reselecting Aux on the dash (iDrive). In my experiment, this (selecting or reselecting Aux) appeared to "turn on" or make the Sure HiFi appear on the Bluetooth list. Once it's listed, then the exercise of selecting it but it won't connect. Sometimes (prolly initially) it appears as Hex, then later as the name.
It's just too much running around the block to only get a muffled sound. My plan going forward is to revert back to the Aux cable until I can narrow down the right year etc OEM BMW TCU to purchase.
FYI: What I mean by getting in and finding out instructions where not as easy as stated. Others used the cigarette lighter in the rear to tap for power source. I've made it clear I was using the front since that's where my Aux cable is located. Well getting to the bottom side of the front cigarette lighter was a roadblock. Couldn't find info nowhere w/my stereo NOW out!! I found and used the cigarette lighter under the passenger side glove box. After pulling the panel (underneath the glove box) the wires and plug are right there to pull out. Plus, the lighter is labeled pos/neg on the cover for semi-novices like myself. I used the blue 3M Quick Connects to tap into the wires to my power plug I bought. All of my connects are a simple plug in for the Aux, and plug in for the power - no soldering!! Clean is what I wanted!!
Hope this helps others still searching for Bluetooth answers for their non "enabled" Bluetooth E60!!
