ATT BB phone paired but no phone book
I have a att blackberry, company's phone, paired with my 2008 528 lci. but no phone book down loaded.
at least, is there any way to create a phone number list with iDrive manually?? it's pita to make a phone call without saved phone numbers.
thanks
thanks
My Ride: 05 545/6
check the bluetooth options on the blackberry and look at the "Contacts tranfer" option. you probably want it set to All, but Hotlist or Selected would help you trim down the list if you have too many.
also, the company can block the BB from transferring contacts, so that might be the other issue, but check the settings first. If you don't see a "contacts transfer" option on your bluetooth options screen they probably blocked it.
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
The other thing that can mess you up with BB's is if your company forces a screen lock, the phonebook wont transfer to the car (or register in the car) if the BB screen is locked.
Vman33
03-14-2022 04:43 AM
brooklynbmw
09-16-2015 01:41 PM
umnitza
09-02-2015 11:28 AM
