Anyway to remove the SOS idrive error?
Old 03-21-2011, 07:06 AM
txag_530i's Avatar
Originally Posted by BLooD
I would imagine the TCU needs coding to tell it disable the SOS function thats all.
I changed the value of E-CALL_HARDKEY_FITTED in the TCUM module to nicht_aktiv. I turned off the key, waited for 10 seconds and when I turned the key back on the error code was cleared and I no longer had the error. I didn't have an account anyway I and I don't plan on getting an account so the functionality isn't something that I'm going to miss. It sure beats going to the dealer and getting a new module installed!
Old 03-21-2011, 09:26 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Originally Posted by bruce_miranda
Just code the KOMBI to remove the check for the SOS.
Bruce, I would be interested in knowing the entry as well.
Is it:
TCM_ALIVE_ZAEHLER
aktiv ----> nicht_aktiv
TCM_ID_MONITOR
Old 03-21-2011, 11:34 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
I guess I answered this myself. I set both of the entries above to not active, and now my SOS error is gone. Yay!
Now, Bruce, is there an entry to disable the passenger restraint check as well?
Old 04-23-2011, 08:15 AM
Gufy's Avatar
I replaced my bluetooth module ... (my bmw made in Germany) to working module but this module from USA car (from e92)... all is working great.
But "SOS failure error".
I have not module TCUM.
TCM_ALIVE_ZAEHLER
TCM_ID_MONITOR
i checked it and i already have "nicht_aktiv".
Maybe any other solutions?
Old 04-03-2012, 04:29 AM
smercki's Avatar
Hello, I have the same problem in M5
solution???
Old 04-11-2012, 05:28 AM
spediegunz's Avatar
hmm i gotta try that ecall hard fitted
Old 04-11-2012, 07:58 AM
spediegunz's Avatar
Edit tried it but that didn't work either
Old 04-18-2012, 08:56 AM
txag_530i's Avatar
Unfortunately, the error has returned to my car. I found this SI Bulletin that may be of some use. Has any added +TELD to the vehicle order and know what variables are changed?
SI B84 17 07 SOS Inactive Warning.pdf
Old 04-27-2012, 03:07 AM
spediegunz's Avatar
Did you ever try to change the VO can you tell me what was your result?
Old 05-21-2012, 06:41 PM
txag_530i's Avatar
I did try to change the Vehicle Order, and then code the MASK, TCUM, and KOMBI modules using the default settings for the new factory order.
(See here for more details.)
I turned off the key, waited for a minute, and then turned the key back on, and had no error message!
And then about 2 minutes later I got the dreaded SOS error message, again. So now I am at a loss as to what to do. Would any other modules have parameters that activate the BMW Assist?
Quick Reply: Anyway to remove the SOS idrive error?
