Address Book Sync Up
Currently i am using a tmobile blackberry 8700, before this i was using a cingular razr. With both phones i seem to have had the same problem.
My address book tends to only sync up with teh car once in a while. there are tiems it works perfectly adn times where my numbers dont transfer to my car.
what can i do to fix this?
I have not seen any posts in the car or phone forums that define when the synchronization takes place. In actual use, I have seen it work in minutes or days and I can't explain that.
You can delete the phone from your I-Drive and re-pair it again, which will force a synchronization in a few minutes, or just accept the way it works.
I also have the T-Mobile BB 8700.
My problem is that the address book only reads the letters A-E.
At first, all the letters were readable, but then something happened and now I only see A-E in my address book.
Regards,
Regards,
My Ride: 2005 525i Titanium Silver Metalic and 2003 325xi Jet Black with the Premium Package in both cars.
I switched from a S/E T637 to Cingular Razr V3 and the phone syncs each and every time. I have not experienced your problem.
