03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
Old Mar 6, 2020 | 11:00 PM
  #111
Leon Naidoo's Avatar
My Ride: E60 530D 2006
If you get the Bluetooth TCU it can be coded
I have a existing TCU BUT IT DOESN'T SHOW BLUETOOTH SIGNAL ON IT.
CAN THIS TCU BE CODED FOR BLUETOOTH BECAUSE I DO HAVE THE FETURE ON THE CAR BUT IT DOESN'T SELECT IT.
Old Mar 7, 2020 | 10:26 AM
  #112
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
If you doesn't have the Bluetooth symbol then no it can't. You would have to get a used one and code it.
Old Mar 7, 2020 | 10:28 AM
  #113
Also check to see if your car has all the connections installed. The attached pic shows the 4 plugs that need to be connected.
Attached Thumbnails 03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&-photo822.jpg
Old Mar 28, 2020 | 07:58 PM
  #114
theruningman's Avatar
My Ride: bmw
Default i have a 2004 bmw 545i i need my tcu coding
Originally Posted by brendinernst
So I have been told by every dealer that the service bulletin that says that cars produced between 03/04 thru 08/04 cannot have bluetooth until the car has the proper TCU put in. This is a LIE I have been coding with NCSExpert for a while now and I dove into the bluetooth coding last night and I am making calls through my car today! So for anyone that has been told "no" I am proof that that is a lie. I am in OHIO and if you would like me to activate your bluetooth PM me.
can you code my TCU for me,
Old Mar 28, 2020 | 09:16 PM
  #115
You still live in GA and is the TCU the exact same as the one you took out
Bteljuice
Nov 26, 2008 09:26 PM
HPLouis
13
Jul 12, 2007 08:07 PM
dv8ed
Nov 16, 2005 11:33 AM
gwf545
May 20, 2005 11:52 AM
jerryleguer
16
Mar 21, 2005 05:25 PM
