03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
Old 04-11-2014, 01:59 PM
  #81
545iMike's Avatar
My Ride: 545i
Having problems detecting the car on my phone. I've done all the coding and added to the VO. Everything shows up in I-drive but my phone won't detect my car. (iphone 5c) I have 84119120760 Bluetooth module, and all the cables are plugged in. Any ideas?
Old 04-12-2014, 01:45 PM
  #82
545iMike's Avatar
My Ride: 545i
Never mind last post. I got it working. Helps if you read pairing instructions properly.
Old 05-05-2014, 05:52 AM
  #83
anoos84's Avatar
My Ride: E60
after coding as you posted, i got massage on idrive says (please activate phone)...
any solution ?? do i have to get specific Pin code (maybe written on my tcu) to pair with my phone ??
thanks in advance
my car 530i 2004 e60 without navi
Old 06-04-2014, 05:47 PM
  #84
havbeemerwilltravo's Avatar
My Ride: E-60 BMW Assist, Tit Silver, Harmon Logic Sound
I am having the same issue. What did you do to fix it? Thanks
Old 06-06-2014, 04:12 AM
  #85
545iMike's Avatar
My Ride: 545i
Just read the pairing instructions. After I did all the coding I missed a step when pairing. Cant remember which one. I think I wasn't in the right menu in i-drive when pairing.
Old 10-21-2014, 11:01 AM
  #86
Gangplank's Avatar
My Ride: '04 545i
Originally Posted by Rizbel
I talked to the seller and convinced him to swap the 2008 TCU with a 2007 TCU and he agreed, I just have to return the item and pay for shipping for the 2007 TCU. What a great eBay seller (sfvautoparts )
Hoping this one will solve the problem, although the TCU manufacture date is 10/2007 and not earlier than 05/2007.
Did the 2007 TCU work for you? I ordered a TCU and just read this thread and noticed the 08 may or may not work in my 2004 545i.
I have the BT prep, mic, etc. The one I ordered is part no. 84109181276 and shows a build date of 01.05.2008. It is GSM and shows IMEI... will be getting it coded at my Indy and using an Iphone 5s.
Any info appreciated....
Old 10-21-2014, 12:12 PM
  #87
Gangplank's Avatar
My Ride: '04 545i
Interestingly when I put the part no. into REALOEM.com I can cross reference to the 04 E60 and it lists the part as applicable.
01 Telematics control unit GSM/US 1 03/2008 84109181276 ENDED
But if I use my VIN it only shows CDMA TCU's.
Does anyone know if it matters? I bought a GSM TCU w/ the oldest build date I could see. GSM = Iphone so hopefully it will work.
Old 10-22-2014, 04:18 AM
  #88
530dA's Avatar
hello guys,
try this:
first step.
delete 638 in FA, enter 633 in FA write to cas and lma with expert profile.
then load new profile in ncs expert profile.
go to cappl and code to default setting and make a reset on cappl then go to the phone ecu in ncs code it on default setting and make reset.
i think so muss it work.
if not, change date of car to 03\05 and then go to the capll ecu and code it on default setting the same for the phone ecu code then make reset for both ecu's
ps: if the tcu 1.5 is comming from car 2008 that can give a problem with software , better to flash the car to the newest software.
let me know if it work.
Old 10-22-2014, 09:56 PM
  #89
Gangplank's Avatar
My Ride: '04 545i
I think my car was just updated to the latest software. Fingers crossed for next week when I have it installed & coded.
Old 10-24-2014, 05:08 AM
  #90
Gangplank's Avatar
My Ride: '04 545i
I'm planning to use an iphone.
Does anyone know if it matters if the TCU is the GSM model or the CDMA model?
Why do they make 2 different vs all in one?? Does it affect the SOS feature? Can I code out the SOS if needed?
Quick Reply: 03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
