So I have been told by every dealer that the service bulletin that says that cars produced between 03/04 thru 08/04 cannot have bluetooth until the car has the proper TCU put in. This is a LIE I have been coding with NCSExpert for a while now and I dove into the bluetooth coding last night and I am making calls through my car today! So for anyone that has been told "no" I am proof that that is a lie. I am in OHIO and if you would like me to activate your bluetooth PM me.
What type of BT do you have ? I have the BT-TCU in my car that has the Bmw Professional phone installed , is it possible to do code this model as well ? Thank you , and sorry for my bad english .
Originally Posted by brendinernst
(Post 1424214)
Hi I just ordered my new TCU from BimmerNav and I will install it myself but can you help with the programming I need to get done? If so How? Any help you can provide to me will be greatly appreciated. My name is James and I'm I'm Baltimore MD, USA and my direct email is philly350zr@verizon.net. My VIN last seven numbers are: B109225 2004 BMW 545i. Please let me know something so I won't have to use the Dealer ! Thanks in advance again ! James |
Originally Posted by jtmone
(Post 1424388)
Originally Posted by Maxxone
(Post 1424366)
(Post 1424214)
Hi The parameter's that you change , what are they ? it would be a great information to know , or is that a National secret ? :confused: Regards BenAnd/Denmark |
Originally Posted by BenAnd
(Post 1425579)
Hi
The parameter's that you change , what are they ? it would be a great information to know , or is that a National secret ? :confused: Regards BenAnd/Denmark The following changes will ne to be made in the TCU and MASK ---TCU--- BLUETOOTH aktiv PORTABLE_BT aktiv ---MASK--- PHONE_MULF aktiv PHONE_BUSINESS aktiv PHONE_PROF aktiv BLUETOOTH_NODES_MASK profil_2 I also noticed you are in Denmark so you may need to change the following in the MASK as well: ECE_TELEFON aktiv This is for European phones. |
(Post 1426355)
---TCU--- BLUETOOTH aktiv PORTABLE_BT aktiv ---MASK--- PHONE_MULF aktiv PHONE_BUSINESS aktiv PHONE_PROF aktiv BLUETOOTH_NODES_MASK profil_2 I also noticed you are in Denmark so you may need to change the following in the MASK as well: ECE_TELEFON aktiv This is for European phones. Hi brendinernst Thanks a lot , super with information's like that :thumbsup: Kind Regards BenAnd/Denmark |
hey man I'm about to do the retrofit myself I'm kinda a ncs beginner I can get things done but i kinda gotta follow directions to do it, lol with that said I found these instructions online
You will need to add the correct FA to the VO first. Read out the trace from the TCU module and set :- BT_ENABLE aktive USED_MICROPHONES wert_01 (1 microphone) or wert_02 (2 microphones) Read the trace for CAPPL (ccc_app) and set:- BLUETOOTH_NODES_CCC profile_1 or profile_1 (not sure on this one, mines profile_2) TELEFON_TYPE_C08 lots of options on this one (mines set to ece_phone for european mobiles) PHONE_VERSION most-phone1-1mic Read the trace for CCC_ASK (ccc-audio) and set:- PHONE_VERSION most-phone1-1mic I want to know in comparison to your instructions how does this differ and what will work better for me I have CCC not m-ask and my car is an 04 im just upgrading to a bluetooth tcu |
Originally Posted by spediegunz
(Post 1426666)
