F1 Autohaüs | Stoptech SS Brake Lines and Brake Fluid Kit
My Ride: 2005 330I ZHP
F1 Autoha?s | Stoptech SS Brake Lines and Brake Fluid Kit
<div align='center'>
Front and Rear StopTech Stainless Steel Brake Line.
3 Bottles of Motul RBF 600 Brake Fluid
For A GRAND TOTAL OF $199/Set</div>
StopTech SS Brake Line Description:
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation.
StopTech brake lines consist of a Teflon? inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing.
All StopTech Stainless Steel Brake Lines are DOT (United States Department of Transportation) compliant and 100% tested to a pressure of 4500 psi.
Motul RBF600 Description:
100% synthetic fluid for hydraulic-actuated brake and clutch systems. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems.
EXTREME THERMAL RESISTANCE AND STABILITY: the elevated boiling point of RBF 600 FACTORY LINE (312 C / 593 F) enables effective braking even under the extreme conditions of competition.
VERY EFFICIENT IN WET CONDITIONS: the very high wet boiling point (216?c / 420?F), is superior to conventional brake fluids and provides a particularly efficient braking system in rain and retards the apparition of vapor lock. NORMES : FMVSS 116 DOT 4 / SAE J 1703 / ISO 4925.
(Note: Centric is the parent company of StopTech and Power Slot. StopTech SportStop and Power Slot rotors start as Centric blanks and are machined in-house on computer controlled milling machines.)
-Anthony@F1 Autohaus
socale39
09-05-2023 08:30 AM
545iMike
10-10-2015 08:37 AM
TexaZ3
05-06-2015 09:54 AM
