EuroRev | Vorsteiner CS-01 1 Piece Cast Wheel
Old 02-09-2010, 03:05 PM
  #81
John Photography's Avatar
Originally Posted by olskooldj
LOL - my thoughts exactly.
John, you are a trooper for following through with photos, given the situation.
You'd make an excellent battlefield photographer for Time Magazine!
Btw, wheels look great on your car!
thanks bro! the wheels look better once it's on the street and not up on the flatbed!lol
nice sig!
John Photography is offline
Old 02-09-2010, 07:59 PM
  #82
v_therussian's Avatar
Wow do I feell like a douche for busting your chops now! hope you get the car back soon and the splitter fixed/replaced.
Now, how did those wheels kill your fuel pump?! LOL joking
They do look sick! These are at the top of my list now for sure
Hang in there John! Btw did you get a loaner to abuse in the meantime?
v_therussian is offline
Old 02-09-2010, 10:26 PM
  #83
Vlad, don't sweat it bro....cuz' i'm not. the car and the splitter will be repaired, no worries.
the wheels do look sick! and no, i didn't get a loaner.....had another car at the time.
Old 02-11-2010, 10:45 PM
  #84
Just found some more info on these.
First, here's a listing of all available sizes and offsets for BMW bolt pattern:
19x8.5 ET25
19x8.5 ET35
19x9.5 ET25
19x9.5 ET33
19x9.5 ET40
Can someone (John? or John? ) confirm these sizes and if possible, provide weights?
Second, I've spoken to a "reliable source" regarding Xi offsets.
Calton's 530Xi ran the following setup (successfully! Dropped on KW V3s):
Front
19x8.5 ET40 10mm Spacer (effective offset ET30)
Rear
19.9.5 ET45 12mm Spacer (effective offset ET33)
Hence the perfect staggered setup for an Xi with these rims would be 19x8.5 ET35 up front and 19x9.5 ET33 rear. NO SPACERS REQUIRED!!!
I do believe there is still some room to push it more with rolled fenders and get the ET25s in there - front and back, but this is kind of a gamble, so use this information at your own risk.
Notable also, the tire sizes 245/35/19 front and 285/30/19 rear match front and rear overall rolling diameters the best (as opposed to the 275/30/19 in the back), which means that the rear will definitely rub on an ET25 rim. But I think a slightly stretched look on an ET25 rim would look sick too - wish there was an overall rolling diameter calculator for a stretched tire fit though... E?
And third... errr... ly and finally, its Friday...
Old 02-11-2010, 10:58 PM
  #85
PraiseTheLowered's Avatar
19x8.5 ET25
19x8.5 ET35
19x9.5 ET25
19x9.5 ET33
19x9.5 ET40
Front
Rear
well also factor in with all those piroskys you eat, that even with the smaller tires youll still rub
lol in all seriousness though the sizes you are looking for seem they will work with your xi, the other factor is tire brand. Some are taller/wider/shorter than others in the same sizes. Falken tends to run more squared and shorter and Toyo is more round and still short but not as much as falken
PraiseTheLowered is offline
Old 02-11-2010, 11:14 PM
  #86
I have been gaining weight a bit lately...
Thanks for sharing the knowledge on the tires Bro
Old 02-12-2010, 01:09 AM
  #87
...Falken tends to run more squared ...
These falkens here look pretty round...
Old 02-18-2010, 07:02 PM
  #88
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
John did you get your car back yet?
tex_phil is offline
Old 02-18-2010, 08:19 PM
  #89
monsterj34's Avatar
i thought it would be more concave... i was debating this or miro 111 again... i might have to go with miro....
monsterj34 is offline
Old 02-18-2010, 08:23 PM
  #90
WTF? Didn't you just sell a set of 111s?
BTW this is way better than Miro IMHO. The only competitor to these rims AFAIK are the Forgestar F14s.
Quick Reply: EuroRev | Vorsteiner CS-01 1 Piece Cast Wheel
