BMW GT1 DIAGNOSTIC TESTER(DK2.1)-Scanners,BMW OPS
BMW GT1 DIAGNOSTIC TESTER(DK2.1)-scanners for sale,this scanners is brand new.
Bmw opps brand new
Here is full information:
BMW GT1 DIAGNOSTIC TESTER(DK2.1)-scanners for bmw
- BMW Group Tester One (GT1) is specially offered to the BMW workshops & service center with the same specification that is currently supplied to BMW franchised dealers. It is the special-purpose diagnostic and programming tool of ALL BMW Series.
- GT1 is supplied with IBM T30 laptop for DIS(Diagnostic and Information System) and SSS(Software Service Station)
- GT1 can covers ALL the systems of ALL BMW series cars, It is used to communicate with Electronic Control Unit (ECU) for diagnosis and programming. All the BMW cars with ECU system can be scanned by GT1 system, using DIS, and be programmed using SSS; With GT1 system, you don??t need to split all the parts with fault in the BMW car. GT1 help you to read the fault code, and do diagnosis, programming.The BMW GT1 system allows you to reprogram all the BMW car ECUs to fix software or to install a blank ECU to a repaired vehicle.
- GT1 is the only system that allows you to do this and is absolutely essential if working on Freelander , the GT1 is also the only system that provides all diagnostics and programming for the very latest BMW launched in 2008.
- BMW GT1 software kit comprises of five system ,TIS system(Technical Information System).DIS data system(Diagnostic and Information System); diagnosis system .measuring system and management system. You can test and check data information at same time in GT1.
Function:
- Read faulty codes
- Clear faulty codes
- Data stream
- Activate state
- Programming
- Component test
- Maintenance data information
- Components location
- Wiring diagram etc, TIS and DIS supply all of system diagram of all of BMW car maintainence method and coding information etc
Package List:
- GT1 Yellow Multiplexer(DK2.1)
- 16 Pin OBD-II Cable
- 20 Pin Diagnostic Cable
- LAN Cable
- DIS Software HDD V43,V49, V50 V51, V52 V53 work with IBM T30 laptop.(version optional)
- SSS software HDD V22, V28 work with IBM T30 laptop.
- IBM T30 laptop.(optional)
GT1 with DIS for diagnosis Supported Models:
Vehicle interface via OBD-II or 20 pin socket:
E87, E90, E91, E92, E60, E61, E63, E64, E65, E66, E70, E83, E85, E86, E31, E32, E34, E36, E38, E39, E46, E52, E53, R56, R50, R52, R53
GT1 with SSS for programming Supported Models:
Language Available:
English,German, Turkish,French, Spanish,Italian, Portuguese, Greek,
Japanese, Korean.
BMW OPS
Introduction :
OPS is mainly used for diagnosis and programming BMW vehicles after E65 series .
OPS unit with DIS software is used for diagnosis , which is carried out via OBD-II socket .OPS unit with SSS software is used for programming , which is carried out via OBD-II socket and MOST socket .
Commodity : BMW OPS
Standard Configuration:
1. OPS multiplexer
2. OBD-II diagnostic cable
3. LAN cable
4. OPS MOST cable
5.80G HDD with preinstalled SSS V20 for IBM T30
6.80G HDD with preinstalled DIS V52 for IBM T30
Pirce is $795(include shipping)
Bmw opps brand new:$1280(include shipping)
PM or email me for more info scanners is in great condition! MSN: funk0595@hotmail.com, paypal: baoyi18@126.com
Bmw opps brand new
Function:
- Read faulty codes
- Data stream
- Activate state
- Programming
- Component test
Package List:
- LAN Cable
Language Available:
Japanese, Korean.
BMW OPS
Introduction :
Commodity : BMW OPS
1. OPS multiplexer
3. LAN cable
4. OPS MOST cable
S4CH
05-04-2015 09:37 AM
JonathonK
03-11-2015 03:13 PM
