Bilstein PSS10 Coilovers
My Ride: alpinewhite's ride
Let's get these sold! The PSS10 is comparable to the KW v2.
Here are some specs on the coilovers
The Bilstein PSS10 Coil-Over System offers ten vehicle adjustment settings and includes numbered adjusters at the base of the shock body so you know exactly what setting you are on without counting clicks. Set your vehicle low and tight for optimized performance or revert to a more stock-like ride height and handling characteristics.
This system features both coil-over and standard monotube gas pressure shocks with performance level valving along with application specific, progressive rate coil springs. Ride height adjustments can be made on the vehicle without removing the suspension. The solid aluminum spring seat and lock nut allow a selective adjustment of the vehicle's ride height. Spring travel and vehicle body height change, but the spring seat remains pre-loaded throughout the allowable range of adjustment.
* Ride height adjustable from -1.0" to -1.75" (front) & -1.0" to -1.75" (rear. minimum 1" lowering)
* Wrenches to adjust front and rear ride height included!
* Lighter weight reduces wear and tear on suspension components
jimmy,
am quite interested in this package. does this come with the electronic ride control? what is the cost of sending this to NY or LA? I'm from Asia and my stewardess friend would be flying to these two places often and would be great if you could send it to the hotel (that is if the deal goes through, lol)
thanks.
thanks.
