aFe Cold Air Intake System
My Ride: E30 325e & E46 ZHP Vert
An AFE Cold Air Intake System for your E60 is one of the easiest and most cost effective ways to increase your car's performance. The cold air intake replaces your restrictive factory air box which allows for an increased air flow meaning more horsepower. Another feature of the intake is the 16 gauge powder coated steel heat shield. A heat shield makes sure that the intake doesn't use the hot air around your engine and only allows the intake to receive cooler air, which adds more power. Not only does power increase, but many have observed an increase in MPG. Give your E60 a boost in power while improving fuel economy with an AFE Cold Air Intake.
Detailed Application Guide can be seen on our listing HERE
06-08 525i, 530i, 550i
If you have any questions or comments, feel free to post here or CONTACT US!
If you would like to reach me personally, you can always PM me or contact me via e-mail at Roger@modbargains.com
My Ride: 2011 550i AW - every option
Originally Posted by za3879' post='648844' date='Aug 17 2008, 07:15 PM
Anything for the 04 545 (MT)?
has anyone tried this set up in a 535 if so let me know. i want to know if there is a power increase and if there is any codes thrown from this intake. i kno the bms throws a code and loses power under heat soak
