▀▄ eas | KW Coilovers- Your #1 Source for V1, V2, V3's!
eas is proud to be an authorized KW dealer and supply your BMW's performance suspension needs!
Variant 1
Featuring sporty handling with factory pre-set damping, the KW V1 Coilover system is ideal for customers wishing to rely on the experience of KW's engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests KW's engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved.
![](http://www.europeanautosource.com/images/KW_V1_Page.jpg)
Features:
-Optimally pre-set
-Sporty harmonious damping technology
-"inox-line" Stainless steel technology
-Individually height-adjustable
-Lowering range approved by the German Technical Control Board (TÜV)
-Fully finished complete solutions -High-quality component parts for long durability -Comprehensive documentation for easy use
E39 5-Series: $1,895.00
http://www.europeanautosource.com/ad...series&x=0&y=0
Variant 2
The KW Variant 2 coilover system is intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behavior of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
The rebound adjustment can be installed via an adjustment spindle at the piston rod end, as far as it is vehicle-specifically possible. The rebound damping primarily controls pitch and roll of the vehicle, especially in the low speed damping range which directly influences handling and comfort. Therefore vehicle can be adjusted to the needs of the driver, making the ride variable from comfortable to sporty and stiff, both with improved road handling.
![](http://www.europeanautosource.com/images/KW_V2_Page.jpg)
Features:
-Damping technology with individually adjustable rebound
-"inox-line" stainless steel technology
-Individually height adjustable
-Adjustment parameters approved by the German Technical Control Board (TÜV)
-High-quality components for long durability
e39 5-Series: $2,275.00
e60 5-Series: $2,275.00
Variant 3
The KW coilover suspension system enables the owner to substantially lower their vehicle while retaining enough travel to handle maximum load and dynamic loads during driving. Variant 3 permits an even higher degree of customization to the suspension. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre set by KW engineers.
Important characteristics such as safety, quality and performance are all taken into consideration with each KW coilover design. Each vehicle application is specifically designed and engineered for a proper range of motion, min/max weight loads and min/max lowering. All these requirements are met while retaining it's performance handling characteristics. Each KW coilover suspension is produced with unique stainless steel "inox-line" technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance from the elements.
![](http://www.europeanautosource.com/images/KW_V3_Page.jpg)
Features:
- Independently adjustable damping technology - rebound and compression damping
- "inox-line" stainless steel technology
- Individual height adjustment
- German TUV-tested adjustment parameters
- High-quality components for long life
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
e39 5-Series: MSRP $2,595.00
e60 5-Series: MSRP $2,595.00
Applications (Check links above to see which variants are available for your Vehicle)
1996-2004 e39 5-Series Sedan & Touring
2000-2004 e39 M5 Sedan
2004+ e60 5-Series Sedan & Touring
FREE SHIPPING in the United States.
PM me directly, e-mail, or give me a call if you have any questions, or would like a quote for forum pricing!
Variant 1
Features:
-Optimally pre-set
Variant 2
Features:
Variant 3
Features:
Bank$hot530
07-12-2015 04:36 PM
