▀▄ eas | Rogue Engineering - OCTANE Short Shift Kits
Make your car fun again with a new short shift kit for your car!
Rogue Engineering has designed a short shift kit for several different models of BMW to make your car more fun and exciting. With superior technology that is constantly evolving, they have applied the best only for the best cars
Please note that RE's OCTANE short shift kits are complete kits. All OCTANE short shift kits include OCTANE specific WSRs (which are different from our factory replacement versions) unless otherwise noted. There are no additional bushings or bearings to buy to inflate an artificially low price point. The prices below reflect a kit with all required parts from research at Rogue Engineering.
Some features that should be noted are as follows:
? Rogue Engineering 335i specific shift lever
? Replicating the factory ?double-bend? to emulate the shift knob position
? Full stainless construction with industry pioneering Ertalyte TX bushing material
? No-Play primary pivot
? SAPP lower pivot assembly
? RE Powerband feature
? Modified factory carrier with RE pivot cup installed
? RE Delrin Carrier Bushings installed
? All replacement bushings and washers
Models Supported:
2007+ e9x 335i
Rogue Engineering - OCTANE Short Shift Kit for e60 545i/550i 6SPD
http://www.europeanautosource.com/pr...oducts_id=1975
MSRP: $295
If you have any questions feel free to contact me directly via PM, email, or simply give us a call
Models Supported:
2007+ e9x 335i
MSRP: $295
