▀▄ eas | Macht Schnell - M5/ M6 S85 Performance Underdrive Pulleys
Gentlemen,
EAS is now introducing Performance Underdrive Pulleys from Macht Schnell for your BMW!
Free additional power to your S85 M5/M6?s rear wheels without sacrificing or compromising your BMW?s reliability.
Machined from 6061-T6 aerospace aluminum, Macht Schnell Performance Underdrive Pulleys are strong as well as lightweight to limit parasitic drag from the accessories within a moderate level for maximum performance on or off the track. After machining and engraving, pulleys are then T3 hard anodized for additional strength, anti-corrosion & wear resistance.
Our DualDrive design replaces the Crank Accessory & Power Steering Pulleys, resulting in a 18-20 HP and 16-20ft. lbs TQ gain from reduction in power required to turn accessories and an increase in accessories lifespan due to lower speed. All factory harmonics/balancing are undisturbed.
Macht Schnell Performance Underdrive Pulleys have no negative effect on accessory operation and come fully equipped with new belts.
Performance Underdrive Pulleys Features:
- DualDrive design allows maximum performance, with minor affect on accessory speed
- Proper cooling temperatures are retained at proper levels on or off the track
- Maintains proper alternator speed, allowing sustained levels to sensitive control modules
- Machined from 6061-T6 aerospace aluminum
- T3 Hard-Anodized for maximum strength and corrosion/wear resistance
- No affects to crankshaft dampening or harmonics
- Simple bolt-on installation
Macht Schnell - e9x M3 S65 Performance Underdrive Pulleys
MSRP: $395 + s/h
Models Supported:
2006-2007 BMW e60 M5 6SPD
SMG 2006-2007 BMW e63/e64 M6 SMG
Don't hesitate to contact me directly if you have any questions about this item.
MSRP: $395 + s/h
Models Supported:
ucsbwsr
09-19-2015 10:58 AM
