▀▄ eas | Macht Schnell - Competition Wheel Spacer kits for BMW
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
Here is a recent article in European car:
-An additional online article in European car's Tech section:
http://www.europeancarweb.com/tech/e...gineering.html
-Macht Schnell spacer reference thread with photos and spec details:
http://www.m3post.com/forums/showthr...schnell+spacer
-Macht Schnell DIY on how to properly install spacers:
http://www.m3post.com/forums/showthread.php?t=272915
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders.
Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts in black OEM finish. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US.
Competition Wheel Spacer kit Features:
- Machined from 6061-T6 aerospace aluminum
- Chamfered edges allows installation & removal quick and easy
- Black anodized finish for additional strength and corrosion/wear resistance
- Improve handling by reducing body roll with a wider wheel base
- Included black extended-length corrosion-resistant wheel fasteners
Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm
http://www.europeanautosource.com/pr...oducts_id=2197
Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm
http://www.europeanautosource.com/pr...oducts_id=2198
Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm
http://www.europeanautosource.com/pr...oducts_id=2199
Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm
http://www.europeanautosource.com/pr...oducts_id=2200
Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm
http://www.europeanautosource.com/pr...oducts_id=2201
Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm
http://www.europeanautosource.com/pr...oducts_id=2202
Spacers start at $49 for 3mm up to $129 for 18mm.
Models Supported:
2008+ 1-series
1992+ 3-series, including M3 (e36, e46, e90, e92)
2004+ 5-series, including M5 (e60)
2005+ 6-series, including M6 (e63, e64)
2004+ X3 (e83)
2000+ X5 (e53, e70)
2003+ Z4, including M-Roadster/Coupe (e85)
2001-2003 Z8
1996-2002 Z3, including M-Roadster/Coupe
All sizes are currently in stock and available for immediate shipment.
Models Supported:
2008+ 1-series
2004+ X3 (e83)
2000+ X5 (e53, e70)
2001-2003 Z8
My Ride: 2007 BMW 550i Jet Black | M5 19" Wheels | Umnitza Multi-Colored Angel Eyes, Fogs, and Low Beams | Umnitza Stealth Grill
David
I'm really interested in these. Whats the best way to figure out the correct size? Feel free to PM me. Thanks!!
TroyE60
05-30-2019 05:01 PM
chadillac2000
42
09-13-2017 11:15 AM
