Arnott Intros New Rear Air Struts for '02-'08 7 Series with and without EDC
Arnott Air Suspension Productsis pleased to offer new, notrebuilt, Right Rear and Left Rear Air Struts for the 2002-2008 BMW 7Series (E65 & E66 chassis) with and withoutElectronic Damping Control (EDC).
The four ArnottŪ Part Numberscomprising the Right Rear and Left Rear Aftermarket BMW Air Struts -- withand without EDC -- include: -- AS-2978: New Right Rear Air Strut with EDC -- Replaces OE Part Numbers: 37126785536 37106778798 37126758580 -- Replaces OE Part Numbers: 37126785535 37106778797 37126758581 37126767127 37126758579 -- Replaces OE Part Numbers: 37126785538 37106778800 37106767864 37126758574 -- Replaces OE Part Numbers: 37126785537 37106778799 37106767863 37126758573 Arnott's aftermarket replacement struts featurea heavy-duty Continental ContiTech air spring bladder and a shockcustom-designed for the 7 Series with a larger piston to provide excellent ridequality and stability. Arnott assembles these new struts in theUSA using the highest quality materials including a CNC-machined top mount andbottom air spring perch made of aircraft-quality aluminum, new crimpingrings, O-rings, bump stop, an aluminum can, air fitting and protective dustboot. These all new struts turn off any dashboard suspension warning lights andcome pre-assembled for an OE fit . The new Air Struts retail for $549 each and arebacked by the company's renowned Limited Lifetime Warranty. |
