Anyone know how to access the backside of the fogs to replace the bulbs? I took off the lower grills in the front and center but not enough room to squeeze my hand in behind them. At a loss unless I just remove the housing from the front.
Anyone?
sorry cant help you with the 750 because i had a pre face lift car
Im not in front of a 750 right now, but I think you can get to it by removing the lower splash guards.
Thanks Sam, will check that out and see what I can find. I looked at those before but since the car is lowered, hard to see clearly so was hoping it was an easier location.
Originally Posted by Sam@sleekmotoring' post='921620' date='Jun 23 2009, 07:01 PM
turn the wheel all the way to the left or right and remove the bolts for the wheel well. then u can reach in and access it
Brabus, thanks pal, will do that, easy enough
rotate your wheels to the left or right and remove bolts from the wheel well
