Transmission Problems!
Old 02-04-2009, 03:31 PM
  #31
NWS Alpine's Avatar
Originally Posted by tbal' post='785231' date='Feb 4 2009, 06:22 PM
lol, there is also a SIB for the e60/e63s with the harsh 1-2 downshift/accelerate problem.
Is this for the SMG or AT? I have something similar in my SMG. When I let it coast to a stop and downshift to 1st the car slows down then it almost releases and jumps forward. It's kind of annoying.
Old 02-04-2009, 04:56 PM
  #32
tbal's Avatar
My Ride: See sig :)
This Service Information bulletin supersedes S.I. B24 03 05 dated June 2005.
designates changes to this revision
SUBJECT
Harsh 2-1 Downshift
MODEL
E60 (5 Series) with N62 and GA6HP26Z produced from SOP up to 9/2005
E63, E64 (6 Series) with N62 and GA6HP26Z produced from SOP up to 9/2005
SITUATION
The customer may complain of a harsh downshift under the following conditions:
1. When slowing to a stop
2. Reaccelerating from a stop or a rolling stop
This maybe most noticeable on an uphill or rising gradient road, however it is usually difficult to
reproduce.
CAUSE
EGS software calibration.
CORRECTION
On a customer complaint basis only, follow the procedure below:
Perform a "Short test" and correct all Drivetrain related faults first.
Submit a Puma case titled "2-1 Tip-In Code" to obtain the access code needed to complete the retrofit
reprogramming of the EGS module.
Please refer to the retrofit procedure as described in SI B09 05 01.
Start a Progman session using only V24.01 or higher and select "2-1 Tip In" from the Retrofit options
menu.
Important:
Transmission temperature must remain below 50 deg C and transmission must be in the PARK position
prior to the start of programming.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
SI B 24 03 05
Automatic Transmission
February 2007
Technical Service
Page 1 of 2
http://www.bmwtechinfo.com/tiscode/cgi-bin...ins/htm_store... 4/29/2008
Defect Code Refer to KSD
Labor Operation: Refer to KSD
Labor Allowance: Refer to KSD
[ Copyright ? 2007 BMW of North America, LLC ]
Page 2 of 2
Old 02-08-2009, 09:45 AM
  #33
jostan's Avatar
Originally Posted by tbal' post='785035' date='Feb 4 2009, 03:34 PM
I guess that shoul've have been in the first post LOL.. it is AT
I have an AT and I'm also having this problem:
"When come to a stop, slight jerking movement, or upon acceleration, same jerky movement. However it cannot ALWAYS be produced, happens time to time."
Had the car for about 4 months now and it has only happened 2-3 times I think.
Also had a problem where the car would accel and decel really quick three times in a row. I pulled up in a parking lot and was going pretty slow. I gently press the gas pedal and car would rev really quick then stop then do it again 3-4 times. I was in sport mode. This only happened once.
Old 02-08-2009, 12:43 PM
  #34
tbal's Avatar
My Ride: See sig :)
Its a problem, same problem I am having, maybe worse... Get it checked out! I have an appointment in 1 weeks time
Old 02-08-2009, 03:05 PM
  #35
jostan's Avatar
I think I'll wait a bit. Doesn't happen very often. Good luck at your appointment, let me know how it goes.
Old 02-08-2009, 09:04 PM
  #36
tbal's Avatar
My Ride: See sig :)
Will do
Old 02-18-2009, 12:43 AM
  #37
tbal's Avatar
My Ride: See sig :)
Finally day has come lol, lets see what the dealership says.
Old 02-18-2009, 12:59 AM
  #38
PrinceNaz's Avatar
Hey dude! My brother had the same problem with his 545. The dealer quoted him ?5000 for a new transmission. But we believed it could be fixed with a software update, so we took it to another dealer who done the update for ?250. Since the update its all fine now.
Can't believe the dealer was gona charge me ?5000, they wouldn't even try doing the update for me.
Hope this helps!
Nasar
Old 02-18-2009, 04:13 PM
  #39
tbal's Avatar
My Ride: See sig :)
If they change the transmission I would be a happy camper LOL Just a software update not so happy rofl
Old 02-19-2009, 10:44 AM
  #40
tbal's Avatar
My Ride: See sig :)
Update so BMW called, there is nothing wrong with the transmission. Apparently the battery is done and some eletrical wire from the terminal, and their looking at about $1377.60 to fix the problem!
How much does a good heavy duty battery cost of these cars? I am going to change it myself grr
Quick Reply: Transmission Problems!
