5Series.net - Forums
-   6 Series Discussion (https://5series.net/forums/6-series-discussion-27/)
-   -   Transmission malfunctions (https://5series.net/forums/6-series-discussion-27/transmission-malfunctions-150397/)
Trez Fowler Jan 1, 2020 01:53 PM
I have a 2006 650 BMWi that I swapped the engine in. After replacing engine the car was driven for two days no problem. On the second day drove the car to the store and then it would not start back up and has a transmission malfunction flash on the dash. I checked the fluid add three quarts. Still no start. I disconnected the battery and reconnected and it started up, turned it off tried to start but no luck. I notice that I can't hear fuel pump running and the car will not even crank over. No power to the small starter wire when trying to start. I haven't been able to get any engine codes but I get transmission codes that are cf14,cf15,cf16,cf17. Can anyone help
JayArras Jan 1, 2020 07:50 PM
To clarify, is that a 5 Series or 6 Series?
Trez Fowler Jan 2, 2020 04:35 AM
It is a 6 series
JayArras Jan 2, 2020 07:07 AM
I've moved your post to the proper section.
Trez Fowler Jan 2, 2020 08:04 AM
ok thanks I'm not sure if I'm in the right section now I'm looking for reply
JayArras Jan 2, 2020 10:22 AM
This site specializes in the 5 Series, but hopefully someone familiar with the 6 will chime in.
