So in the last couple days I started noticing small jolts as if the car abruptly slowed down for a split second... Today I'm driving along and foot is just rested on the pedal when I fealt a pretty big jolt. It was VERY noticable... anyone have suggestions as to why other than the tranny is screwed?
How do you reset the tranny again? |
I dont appreciate you only post when you need help. Sorry come again, stay away from trannys :P
lol right i only post when i need help lol such a funny guy... you know what I like? Funny guys like you! (can't remember what movie that was from but it popped in my head)
did a reset and it seems to be ok for now. |
It should have done the trick... If not, time for a trip to the stealers :)
if it happen alot try changing the filter and oil
it worked for me btw how many mile have you done? |
Fluid, uh o...
I had the same problem, got a new gasket for the trans pan, new oil... problem was not solved, kept leaking, I went ahead and replaced it with a brand new pan (which comes with the built in filter) To change the filter, you change the WHOLE pan... go figure... $600 later the problem was rectifed. |
Yup. there's a hairline fracture (prob. from bottoming out) in the trans pan and it has to be replaced. at the shop right now but it's costing me 1100:(
WTF why so much? Trans pan w/ filter gasket is $195 shipped! Zf oil another $150 ish plus labour... $1100 something sounds wrong!
