How to change the reverse lights?
Old Dec 17, 2008 | 08:18 PM
jchris's Avatar
Title says it all.
Thanks to all!
JC
Old Dec 18, 2008 | 03:21 AM
schulrog's Avatar
it's pretty easy man.. open trunk and pull out the cover where the taillights are.. then i think you undo a clip and the mounting for the bulbs comes out. just try it, it's really simple to do
Old Dec 18, 2008 | 11:13 AM
flyingpuck's Avatar
Hmmm, I think you should make an appointment at the dealer for this! It's as easy as described above! Good Luck!
Old Dec 18, 2008 | 11:21 AM
cobradav's Avatar
Originally Posted by jchris' post='747704' date='Dec 18 2008, 12:18 AM
Title says it all.
Thanks to all!
JC
Remove rear bumper. Cost estimate in USA is $240 (+/- $20) at dealer to replace one (or two) bulbs.
Not sure if Rudy has TIS info for DIY. I'll look around and see if I do
Old Dec 18, 2008 | 12:17 PM
schulrog's Avatar
uhh what are you removing the rear bumper for? lol As far as I understood it, he just wants to change the backing up bulb in the taillights.
Old Dec 18, 2008 | 01:15 PM
Lucardes's Avatar
Backing lights are in the bumper silly the taillights one are the signal ones.
Old Dec 18, 2008 | 01:24 PM
schulrog's Avatar
oh SHIT that's right! there is NO WAY BMW would design the car that way where you have to take the bumper off to switch a bulb.. absolutely no way!
It's like switching the headlight bulbs.. dealer told me had to take the bumper off.. yeah right! After enough lookin around i found a flap in the wheel well that openes up to switch the headlight bulbs
Old Dec 18, 2008 | 01:41 PM
tbal's Avatar
My Ride: See sig :)
Think again, according to TIS, you will HAVE TO remove the rear bumper to access the reverse lamps. Once you remove the rear bumper, its obvious to see how to install the new bulbs. If you need directions to remove bumper, let me know.
Old Dec 18, 2008 | 01:46 PM
Lucardes's Avatar
Schulrog - 0 Everyone - 2
Old Dec 18, 2008 | 02:17 PM
tbal's Avatar
My Ride: See sig :)
lol
