does anyone have problems with their kw-suspension?
Old 09-25-2009, 11:05 PM
RC688's Avatar
My Ride: 2004 645cic, 20" asanti wheel with KW Coilover Variant 3
my KW V3 are have some problems! the 2 rear top part of the coilover are keep on pump up from inside of the Convertible Cover approx 3 to 4" high (there is a suspension cover cap that mount on top of the coilover when you install). only way you can fix it is by lifting the back of the car up with a car jack then the coilover will return back to the position. but time to time will pump again! So now i can not have the convertible top down! The shop that i buy from think that suspension might be too stronge for my car and KW doesn't make any aftermarket cap for it. Not sure what to do now? maybe i should remove them back to stock! Does anyone have the same problems or does anyone know any company make any aftermarket coilover cover cap are much stronger that the OEM parts? or maybe i should buy some other brand? or maybe not coilover? any suggestion?
RC688 is offline
Old 09-26-2009, 10:04 AM
Sam@sleekmotoring's Avatar
When you say that the coilover " are keep on pump", what exactly do you mean? Is the shaft, and the upper whshers and bolts of the actual shock moving up way past the upper perch?
Sam@sleekmotoring is offline
Old 09-26-2009, 10:46 AM
BMRMEUP's Avatar
My Ride: 2008 535i Monaco blue/cream beige, light poplar trim, sport, nav, premium, Logic 7, 6 speed manual My other rides: Departed: 2006 530xi Silver gray/black, anthracite maple trim, cold, sport, nav, premium, Logic 7, 6 speed steptronic, bluetooth, adaptive xenons Departed...2002 525i White/beige, 5 sp manual
Have you contacted KW directly? I'd be interested in their response. Does look like they make a street comfort coilover for your model as well.
BMRMEUP is offline
Old 09-26-2009, 06:33 PM
RC688's Avatar
i'm not sure what it call??? but is the inside of the center part "Silver Bar" which push up from the center of the suspension cap! Car still hold on, but it feel like you have no shock at all (is mostly happen to my right rear only) but it also happen to my left side one time too! The last time i bring car for service to BMW dealer they though my KW suspension break the suspension cap. So i have them to replace all 4 caps and it cause me over $1000 with labor! and now it happen again. so i don't think the cap break at all, i think this is how it design if suspension are have problems it will not break the whole thing! but i will try to take some photo, if it happen again. As far as i know, KW don't have any reply yet! And the KW wholesaler said if is defective. They might be able to do something. but if is something else then nothing they can do! i think i might have to content KW to find what happen! but not sure are they going to do anything about it?
RC688 is offline
Old 09-26-2009, 08:43 PM
BMRMEUP's Avatar
Have you checked the model number of the shocs they mounted against the model shown for your car on the KW site?
BMRMEUP is offline
Old 09-27-2009, 01:07 AM
RC688's Avatar
Yes, they are the right parts#
RC688 is offline
Old 10-11-2009, 02:11 PM
Not sure of the problem but I have been told that the KW are the best coilovers for the 6. I have the H&R coilovers and they are horrible. Their Customer Service is horrible too.
If I had a choice, I would of went KW. Just give KW a call. Im sure they will help out.
hipertec is offline
Old 10-11-2009, 03:10 PM
BMRMEUP's Avatar
I've been wondering if you ever got this resolved. Was KW any help in determining the problem RC?
BMRMEUP is offline
bbbamboo
09-17-2017 04:33 PM
gergnang
07-01-2015 02:01 PM
RussHamel73
06-03-2015 08:24 AM
gaz
05-29-2015 06:11 AM
E60Japanese
03-23-2015 05:23 PM
Quick Reply: does anyone have problems with their kw-suspension?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
