Clip of 650i with first silencer removed
#21
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
I've borrowed SocalM5Mang's pics from his recent quad conversion.
As you can see two pipes from the headers back to the box resonator. Then exiting as one pipe until just before the two mufflers separating into two pipes again.
x-pipe attached to stock cylindrical resonators (shown) and two universal mufflers (not shown).
#23
In a stock e60 setup, the x-pipe would go on right after the two cylindrical resonators and before the mid-pipe box resonator.
#25
There is one other alternative I didn't present. Remove the two cylindrical resonators and replace it with an x-pipe.
#27
It won't be loud and obnoxious at all. You still have the mid-pipe box resonator and two stock mufflers. The mufflers are the key here. If you remove both mufflers then it will be loud and obnoxious. A great example would be torquey5. He has all three resonators but deleted both his mufflers on his 550i and went with straight pipes.
#30
Resonators are really mini-mufflers. They help "muffle" the exhaust note but their primary role is to cancel out resonance aka droning. The e60 has three of these resonators. IMO, the mid-pipe box resonator does the most resonance canceling. Replacing the two cylindrical resonators with x-pipe should be okay b/c one of the benefits of an x-pipe is that it will help with minimizing droning.
You're welcome, PP. I'm just sharing what I have researched and learned about exhaust systems in my quest to eliminate my droning problem in my E63. I already know the answer and that is to put the stock resonator back on, but I want to find other alternatives before doing so. The E63 exhaust is a little different than the E60. It's very similar to the M5 though. Two primary cats, two secondary cats, resonator and two mufflers.
jinsta
07-22-2015 08:29 AM
PelicanParts.com
07-09-2015 01:07 PM
