Bubble in the sidewall
My Ride: See sig :)
I am positive its not good lol but can I still drive on the tires? Just had 2 newish tires mounted (rears) and each of the tires has a small bubble on the outside side wall. grrrrr
Thoughts?
Thoughts?
My Ride: CLS55 AMG
Thoughts?
Thoughts?
Thoughts?
Thoughts?
My Ride: See my signature
Originally Posted by luigi524td' post='1011880' date='Sep 19 2009, 03:56 PM
I would not drive on tires with sidewall defects (bubbles). If it still has tread try to get a replacement from the manufacturer ... they would not have any way of disproving you were not the original purchaser not that even matters where a manufacturer defect is concerned. Go talk to a tire dealer who sells that brand - not necessary to go to the selling dealer.
Do not drive for a long period of time on a bubbled tire as you are at an inceased risk for a blowout.
Tire warranties suck. What they may try and tell you is that the bubble may have been caused by impact. This means that is could either be a pothole, or driving with lower air pressure than recommended, or a combo of both.
Good luck!
Originally Posted by Sam@sleekmotoring' post='1012098' date='Sep 19 2009, 10:27 PM
My Ride: G30 M550i
Model Year: 2018
In my experiences, especially with low-profile tires mounted on large diameter rims, sidewall bubbles are usually caused by an impact with a pothole or something.
If and when the tire is dismounted, it'll be easy to tell if the bubble is from an impact or from a defect since the impact bubbles usually have sort of a crease or "cut line" on the inside of the tire, just behind the bubble. Bubbles that are a result of a manufacturing defect usually do not have a crease...
