BMW Unveils 330e and 330e xDrive Sedans
By -
BMW 330e and 330e xDrive Sedans
The BMW 330e sedan starts at $44,550 while the 330e xDrive sedan starts at $46,550 before the $995 destination charge.
Over the past 40 years, no single model has embodied the concept of the Ultimate Driving Machine better than the BMW 3 Series Sedan. BMW proudly announced the newest additions to the 3 Series model line, the performance plug-in-hybrid 330e and 330e xDrive Sedans. BMW’s latest eDrive technology, advanced driver assist, safety and infotainment systems allow the new 2021 BMW 330e and 330e xDrive sedans to deliver exhilarating driving experiences while lowering emissions and allowing for purely electric driving.
4-Cylinder PHEV Drivetrain with XtraBoost
The new BMW 330e and 330e xDrive Sedans utilize an intelligently controlled powertrain consisting of an electric motor, a high voltage battery pack and an internal combustion gasoline engine to enhance the performance driving experience of the 3 Series.
A 2.0-liter BMW TwinPower Turbo engine developing 181 hp @ 3,800 – 6,500 rpm and 258 lb-ft of torque @ 1,450 – 3,600 rpm is complemented by an electric traction motor developing 107 hp at 3,170 rpm and 77 lb-ft of torque @ 0 – 3,140 rpm. The combined power output is 288 hp and 310 lb-ft or torque with XtraBoost.
A high-voltage 34 Ah / 12 kWh gross (9.09 kWh net) lithium-ion battery module located underneath the rear seats provides the storage capacity for electric-only and performance-oriented driving.
The estimated EPA purely electric range for the BMW 330e Sedan is 22 miles (20 miles for the 330e xDrive Sedan). The estimated MPGe rating for the 330e Sedan is 75 (67 for the BMW 330e xDrive).
XtraBoost
A brand-new feature in the new BMW 330e and 330e xDrive Sedans, Xrtraboost enhances power and performance when the throttle is depressed to the kick-down position. Available in SPORT mode, XtraBoost offers an immediate 40 hp power increase for up to 10 seconds.
The BMW 330e Sedan’s electrified drivetrain allows it to accelerate from 0 to 60 mph in 5.6 seconds (5.7 seconds for the 330e xDrive Sedan). Both models feature an electronically limited top speed of 130 mph when equipped with all-season tires. When equipped with summer performance tires, the 330e Sedan reaches a top speed of 142 mph (140 mph for the 330e xDrive model).
Purely Electric Driving Up to 87 mph
In the HYBRID driving mode, the new BMW 330e and 330e xDrive Sedans can operate at speeds up to 68 mph on electric power alone, an increase of 19 mph over its predecessor. Emissions-free and fuel-free ELECTRIC mode allows driving up to 87 mph, up from the previous 75 mph. The standard Active Protection for Pedestrians features an exterior speaker system to generate an unmistakable sound created specifically for electrified BMWs when operating in electric-only mode at speeds up to 20 mph.
8-speed Sport Steptronic transmission
The new BMW 330e and 330e xDrive Sedans are equipped with a standard 8-speed Sport Steptronic transmission. The latest version of this quick-shifting sport automatic transmission features a new, optimized hydraulic control system and shorter gearing for improved response and acceleration.
Rear-Wheel Drive or BMW Intelligent xDrive
The BMW rear-wheel-drive performance feel or the all-season capabilities of BMW’s latest intelligent all-wheel-drive system? Your choice with the new 330e models.
The fully variable power transfer of BMW’s intelligent xDrive ensures maximum traction and directional stability in all road and weather conditions while also promoting sportier handling. This functionality comes courtesy of the electronically controlled multi-plate clutch in the transfer case which links up with the Dynamic Stability Control (DSC) system and constantly adjusts power transmission – precisely and in a fraction of a second – in response to the driving situation. In this way, any tendency of the vehicle to oversteer or understeer greatly reduced.
The system’s rear-biased set-up helps ensure the new BMW 3 Series Sedan retains the exhilarating driving experience drivers expect from a BMW. Sending more drive power to the rear wheels under normal driving increases agility when cornering. In situations that do not require all-wheel drive, the efficiency of BMW xDrive is increased by directing all the engine’s torque to the rear wheels. The weight of the system has also been reduced, while optimized oil supply increases internal efficiency.
Driver Assistance Systems
The BMW 330e and 330exDrive Sedans also assume a pioneering role when it comes to assistance systems designed to ease the driver’s workload in monotonous driving conditions – such as traffic jams – and lends a helping hand in awkward maneuvering situations. The new model generation offers a far wider choice of standard and optionally available systems that enhance specific aspects of comfort and safety.
The optional Active Cruise Control with Stop and Go braking function helps to make life easier on long-distance journeys by automatically accelerating or slowing down the car to maintain the desired speed set by the driver. The set speed can be imported directly from the optional traffic sign recognition system’s display.
The standard Active Guard, Frontal Collision Warning with City Collision Mitigation and Lane Departure Warning alerts the driver when a cyclist is detected. Depending on the situation, the system can bring the vehicle to a halt to either avoid a collision or minimize its consequences. And the optional Driving Assistant includes Blind Spot Detection systems help the driver to guide the car back onto the correct path with steering input.
Parking Assistance Package Plus
While the standard Park Distance Control (PDC) provides visual and acoustic signals to prevent collisions with obstacles located to the side or rear of the vehicle, the optional Parking Assistance Package goes further with Automatic Parking, which automatically selects either parallel or perpendicular spaces along to the road, and maneuvering into them. The latest version of the system takes care of steering the car, accelerating, braking and automatic transmission shifting. What’s more, Automatic Parking can now also be used to automatically maneuver out of parallel parking spaces.
BMW Intelligent Personal Assistant
Available in the BMW 330e models is the BMW Intelligent Personal Assistant, an intelligent, digital character that responds to the prompt “Hey BMW”. The BMW Group is set to revolutionize driving pleasure with the BMW Intelligent Personal Assistant and, in so doing, enter a new era in which drivers will increasingly be able to operate their car and access its functions and information simply by speaking. The range of functions and skills available will be constantly expanded as part of regular updates.
BMW Digital Key
The BMW Digital Key employs Near Field Communication (NFC) technology to allow the new BMW 330e and 330e xDrive Sedans to be locked and unlocked from a compatible smartphone, removing the need for a conventional car key.
Expanding Charging Solutions
Improving the charging experience for BMW EV and PHEV drivers is a top priority, and 2020 will see an expansion of access to public charging to provide a more premium and easy to use experience. This service will offer a single, convenient point through which to search for and locate public charging from multiple charging networks, initiate charging of your plugged-in BMW vehicle and facilitate billing.
To take full advantage of the electric-only capability of their BMW plug-in-hybrid vehicle, new and existing customers are able to work with their dealer to receive referrals to local service providers for the installation of a Level 2 BMW i Wallbox charging unit in their home. By choosing a professionally-installed 240v Level 2 home charging unit, customers can enjoy charging up to 7 times faster than with a 120v standard outlet charger.
Recently, BMW began a collaboration with Amazon to offer BMW customers the choice of researching hardware, checking pricing and scheduling professional installation via the easy-to-use Amazon digital platform that they may already be familiar with.
By visiting www.amazon.com/bmwcharging, customers can find out charging times for their specific BMW EV of PHEV vehicle, choose from a selection of best-selling charging units and compare prices, with and without professional installation. An installation estimate is provided based on a simple three-question survey and the customer’s zip code.
2021 BMW 330e and 330e xDrive Standard Features
  • 18-inch V-Spoke bi-color grey wheels with all-season run-flat 225/45R18 tires.
  • Sport eight-speed automatic transmission
  • Sport leather multi-function steering wheel
  • Power front Sport seats
  • 40/20/40 split rear seat
  • Fine Wood trim with Ash Grey-Brown high gloss finishes.
  • Moonroof
  • Auto-dimming interior and exterior mirrors
  • Automatic Climate control
  • Dynamic Cruise control (reduces speed in corners and can apply brakes downhill)
  • Rearview camera
  • Navigation
  • Live Cockpit Professional with
  • Hands-free Bluetooth and USB audio connection
  • Alarm System
  • SiriusXM Satellite Radio with 1 year All Access Subscription
  • Apple CarPlay Compatibility
  • ConnectedDrive Services
  • Acoustic Protection for Pedestrians
  • Lane Departure Warning
  • Active Protection – Automatic front seat belt tensioning, Automatic closing of windows and moonroof,
  • Fatigue and Focus alert, Post-crash braking.
  • Active Guard – Pedestrian warning with braking, Frontal Collision Warning, City Collision Mitigation with braking, Speed Limit information.
2021 BMW 330e and 330e xDrive Optional Packages
  • Convenience Package – Comfort Access keyless entry, Lumbar support, Park Distance Control, LED Headlights with Cornering Lights, Active Driving Assistant* or Driving Assistance Professional, Active Blind Spot Detection.
  • M Sport Package – choice of 19-inch wheels with all-season run-flat or performance fun-flat tires, SensaTec Dashboard, Choice of aluminum or wood interior trim, LED Fog Lights, M Steering wheel, Aerodynamic kit, Shadowline exterior trim.
  • Parking Assistance Package – Parking Assistance Plus, Active Park distance control, Surround Camera View with 3D View
  • Premium Package – Heated Steering Wheel, Comfort Access keyless entry, Lumbar support, Heated front seats or heated front and rear seats, Park Distance Control, LED Headlights with Cornering Lights, Active Driving Assistant* or Driving Assistance Professional, Head-Up Display, Active Blind Spot Detection.
  • Executive Package – Heated Steering Wheel, Comfort Access keyless entry, Lumbar Support, Heated front seats or heated front and rear seats, Active Driving Assistant* or Driving Assistance Professional, Icon Adaptive LED Headlights with Laserlight, Head-Up Display, Gesture Control, Active Blind Spot Detection.
  • Driving Assistance Package – Park Distance Control, Active Driving Assistant* (or Driving Assistance Professional), Active Blind Spot Detection.
  • Dynamic Handling Package – 19-inch M Double-spoke jet black or bi-color jet black Style 791M wheels with 225/40R19 front and 255/35R19 rear performance run-flat tires, M Sport brakes, Adaptive M Suspension, Variable sport steering.
  • Driving Assistance Professional Package – Extended Traffic Jam Assistant for limited access highways, Active cruise control with Stop & Go,
2021 BMW 330e and 330e xDrive Stand-alone Options
  • Heated Steering wheel
  • Adaptive M Suspension
  • Variable sport steering
  • Power tailgate
  • Heated front seats
  • SensaTec dashboard
  • Interior Aluminum or wood trim
  • Ambient Lighting
  • Park Distance Control
  • Active Driving Assistance Professional
  • Harman Kardon surround sound system
  • Wireless Charging
Join the 5Series forums now!
