ALPINA Launching XB7, First Sports Activity Vehicle in the U.S.
By -
2020 BMW ALPINA XB7
To be produced in South Carolina, the BMW ALPINA XB7 features a 612hp 4.4L bi-turbo V8 and is capable of a 4.0-second 0 to 60 time.
ALPINA recently unveiled its first Sports Activity Vehicle for the U.S. market, the new BMW ALPINA XB7. Based on BMW’s X7 model line, the XB7 joins the B7 Sedan in ALPINA’s U.S. lineup this fall. Powering this mighty beast, you’ll find a 4.4-liter bi-turbo V8 producing 612 hp and 590 lb-ft of torque under the hood, making the XB7 capable of running to 60mph in 4.0 seconds. And, with a top speed of 180mph and an ALPINA sport suspension, we expect the XB7 to be among the highest-performing Sports Activity Vehicles in the world.
Order sheets open this month with the first deliveries scheduled for September. The starting MSRP is $141,300 plus $995 Destination.
2020 BMW ALPINA XB7
Here are the full details directly from BMW and ALPINA:
Warp-Speed Power: 4.4-Liter Bi-Turbocharged V8 Engine
A state of the art performance powertrain spawns the powerful and confident character of the new BMW ALPINA XB7, with linear and responsive power delivery across the entire engine speed range. The engine has been carefully calibrated to reflect the superior driving experience that has been signature to the most-powerful ALPINA models throughout the company’s 55-year history. The engine’s character is best described as early, torque-filled urgency followed by a surge of mid-range power and a hard charge to redline.
The 4.4-liter V8 engine with bi-turbo charging, gasoline direct injection, and BMW’s Valvetronic delivers an output of 612 hp @ 5,500 – 6,600 rpm and a maximum torque of 590 lb-ft which is available from an extraordinary 2000 rpm all the way to 5000 rpm. The BMW ALPINA XB7 needs just 4 seconds to accelerate from 0 to 60 mph, and completes the ¼ mile sprint in just 12.6 seconds when equipped with the standard 21-inch wheels and performance tires. Maximum speed is limited to 180 mph when equipped with the standard 21-inch wheel and performance tire setup.
2020 BMW ALPINA XB7 interior
The engine’s power characteristics and superb throttle response are the result of detailed optimizations of the turbocharging and cooling systems. Two twin-scroll turbochargers with 2.1″ turbines facilitate the near-instantaneous conversion of exhaust gas energy into boost pressure, even at low engine speeds for early maximum torque. The cooling system with two additional external water coolers, an enlarged transmission oil cooler and a low-temperature cooling system (air/water/air) with ALPINA’s specific intercoolers, ensure thermodynamic stability even under highest loads.
The all-new, stainless-steel ALPINA sport exhaust system is responsible for the BMW ALPINA XB7’s signature V8 sound. Designed to reduce back-pressure, the system is similar in construction and operation to that fitted to the 3rd-generation BMW ALPINA B7 Sedan also sold in North America. Active exhaust system flaps allow the driver to influence the sound: restrained in COMFORT mode for best possible travel comfort or clearly pronounced in SPORT mode.
2020 BMW ALPINA XB7
Smooth and Fast: Eight-Speed Sport Automatic and Active LSD Differential
The new BMW ALPINA XB7 features the latest generation 8-Speed Sport Automatic Transmission with the industry-original ALPINA SWITCH-TRONIC wheel-mounted shift buttons. In cooperation with the experts at ZF, the 8HP76 transmission has been specially designed to cope with the engine’s high torque. Offering unparalleled shift comfort and the capability to execute shifts in tenths of a second means power is delivered effortlessly and instantaneously at all times.
The high-performance transmission unit features an aluminum transmission oil sump located in the underbody where it is cooled effectively.
2020 BMW ALPINA XB7
The complete redesign of the electronics and mechatronics in this new-generation transmission ensures precise operation and responsiveness. In SPORT and SPORT+ modes, shift points are optimized for driving performance and gear shifts are considerably more dynamic. The COMFORT and COMFORT+ mode allow for relaxed, luxurious cruising at low engine rpms even when travelling at highway speeds, taking advantage of the signature ALPINA torque responsiveness.
The BMW ALPINA XB7 drivetrain features an electronically-variable active limited slip differential on the rear axle, with a locking torque of up to 1475 lb-ft. This improves traction when driving dynamically by ensuring that slip-induced losses are minimized, and torque is distributed effectively to the wheel with the most grip at any given time. The degree of lock is continuously and actively adjusted depending on wheel speed, friction coefficients and steering angle among other things. The behavior of the active limited slip differential unit is specifically calibrated to suit the dynamic character of the BMW ALPINA XB7 and it operates in conjunction with the other driving dynamic systems.
2020 BMW ALPINA XB7
A New Dimension in Driving Dynamics: ALPINA Sport Suspension and Kinematics
 The BMW ALPINA XB7 is fitted with cutting-edge suspension technology, opening a new dimension in driving dynamics for the performance-luxury Sport Activity Vehicle segment.
The standard two-axle air suspension with ALPINA-specific damper and kinematic set-up are primarily responsible for the balance of driving dynamics and ride comfort. It allows for a remarkable and noticeable 1.6 inch change in ride height, depending on driving situation and Mode selection. At speeds below 19 mph, the ride height can be raised by 1.6 inches for challenging ramp angles or other clearance requirements. More importantly, the BMW ALPINA XB7’s ride height can be lowered by 1.6 inches, either dependent on speed or at the driver’s request, resulting in a substantially lower center of gravity.
2020 BMW ALPINA XB7
When selecting SPORT mode or at speeds above 100 mph, the ride height is lowered by 0.8 inch. The ride height is lowered another 0.8 inches for a total of 1.6 inches beyond speeds of 155 mph or when selecting SPORT+ mode. The resulting lower center of gravity and changes in suspension geometry, with associated increases in negative camber, have a significant positive effect on dynamic handling and road holding.
An ALPINA specific dome-bulkhead strut and reinforced torsion struts increase body rigidity. In addition, the electromechanical anti-roll bars of the Active Roll Stabilization system and stiffer rear axle bushings reduce body roll substantially.
2020 BMW ALPINA XB7
Agility: All-Wheel Drive and Integral Active Steering
 The BMW ALPINA XB7 all-wheel drive is based on the BMW intelligent xDrive system, which fully and variably distributes torque as required between the front and rear axles. The ALPINA specific adaptation of the torque distribution maximizes traction and neutral driving dynamics in all conditions.
The Integral Active Steering, standard on the new BMW ALPINA XB7, offers direct steering response with exceptional feedback and improves overall agility. The Active Kinematics Control System from ZF enables the wheels of the rear axle to pivot a maximum of 2.3° left or right. At low speeds, the rear axle steers opposed to the front axle for increased agility and dynamic handling. Conversely, at higher speeds the rear axle steers “with” (congruent to) the front axle for maximum directional stability. The driver can choose from three steering modes: COMFORT, SPORT and SPORT+. While in COMFORT mode the focus is on smooth directional stability and safety at higher speeds while the SPORT mode aims to maximize responsiveness.
2020 BMW ALPINA XB7
Excellent Road Holding with Maximum Grip: Wheels, Tires, and Brakes
Specially-developed wheel and tire combinations underscore the powerful, elegant appearance of the BMW ALPINA XB7 and are instrumental in offering impressive levels of grip and road-holding, especially for a vehicle of this size category.
The new BMW ALPINA XB7 rides on 21″ ALPINA DYNAMIC wheels as standard which can be specified with performance summer or all-season runflat tires, measuring 285/45R21 front and rear.
2020 BMW ALPINA XB7
Optionally, all-new 23″ forged-alloy wheels in the iconic ALPINA CLASSIC 20-spoke design and finished in Anthracite are available. Their high-strength, high-density construction as a result of forging allows a significant weight saving of 28 lbs. per vehicle. In collaboration with the experts at Pirelli, the performance summer tires for the 23″ wheels have been explicitly developed and specified for the BMW ALPINA XB7. Measuring 285/35ZR23 at front and 325/3 ZR23 rear, they provide impressive grip and guaranteed visual presence around town.
Four-piston fixed brake calipers from Brembo with brake discs of 15.5 x 1.4″ diameter on the front axle and floating brake calipers with brake discs of 15.7 x 1.1″ diameter on the rear axle offer excellent and consistent deceleration. Brake calipers are finished in ALPINA Blue and feature a white ALPINA logo.
2020 BMW ALPINA XB7
The Best of Look, Touch and Feel: Design and Equipment
 Expressive presence: each detail of the new BMW ALPINA XB7’s design conveys dynamic luxury. The powerful appearance is accentuated by a modern design language, elegant details, and precise contours that draw attention to its generous dimensions.
The front bumper with large air intakes and free-floating ALPINA lettering is aerodynamically optimized to reduce uplift for maximum high-speed stability. Large air intakes facilitate the effective flow of air to the performance ALPINA cooling system. At the rear the ALPINA sport exhaust system with two twin tailpipes is beautifully integrated into the design of the ALPINA rear bumper. The middle of the rear bumper is accentuated by small diffusor fins.
2020 BMW ALPINA XB7 back seat
The generous interior features three rows of seats as standard. The second row either features a rear bench with three seats or – optionally – two comfortable individual captain’s chairs with integrated armrests. Depending on the seat configuration, the luggage compartment provides capacity ranging from 48.6 to 90.4 cubic feet. For comfortable loading, the BMW ALPINA XB7 can be lowered by up to 2 inches at the push of a button that is located in the luggage compartment.
An extensive range of standard equipment including high-end Merino Leather, Multicontour Seats, Seat Heating, Soft-Close Doors, Alcantara Headliner and a Leather Instrument Panel ensure maximum comfort and a luxurious ambiance for driver and passengers. The standard three-part panoramic glass sunroof contributes to a light and airy atmosphere in the interior, which emphasizes the generous space. To enhance exclusivity even further, the optional Panorama Sky Lounge LED Roof, generates a very special aura when darkness falls, with LED light spreading evenly across the glass surfaces to illuminate more than 15,000 graphic patterns and generate a display reminiscent of a starlit sky.
2020 BMW ALPINA XB7
The interior’s distinguishing details and features which set it apart from the mainstream: exclusive ‘Crafted Clarity’ glass application and iDrive controller in ALPINA design, blue illuminated gear selector switch, ALPINA production plaque, illuminated ALPINA door sills and the unique ALPINA sport steering wheel hand-finished in finest LAVALINA leather and featuring trademark Blue/Green stitching. In addition to the ALPINA Myrtle Luxury Wood interior trim, two further ALPINA trim variants are optionally available: Piano lacquer and all-new Natural Walnut Anthracite. Each of the ALPINA wood trim variants features the ALPINA roundel logo.
The full-color 12.3-inch digital instrument display with ALPINA design features advanced configuration options, sport displays, and customizable views, and forms part of a large display combination with BMW’s traditional driver orientation. The cockpit design offers a convincing user experience, with intuitive operation via a high-resolution 12.3-inch touch display, direct selection buttons, or iDrive Controller, voice, or gesture control.
2020 BMW ALPINA XB7
Full Suite of Standard Driver Assistance Systems
The BMW Driving Assistant Professional included as standard offers a high degree of active safety with its comprehensive package of innovative assistance systems. The systems really come into their own when driving longer distances by relieving the strain on the driver in monotonous situations, such as traffic jams or slow-moving traffic. They enhance comfort and safety both in urban traffic and on longer trips by providing targeted assistance in complex traffic situations. The driver assistance systems process camera images as well as the data gathered by ultrasonic and radar sensors to monitor the vehicle’s surroundings, to warn of potential hazards and to minimize the risk of an accident with corrective braking or steering inputs.
Driving Assistance Professional Package also includes Blind Spot Detection, Lane Departure Warning, Rear Collision Warning, Frontal Collision Warning and Pedestrian Warning with City Collision Mitigation (which now also alerts the driver if cyclists are detected) Cross Traffic Alert Rear, and Speed Limit Information, and Active Cruise Control with Stop & Go function. Active Cruise Control can be used at speeds up to 130 mph and maintains the desired speed while taking not only the traffic situation into account, but also the selected distance to vehicles in front. If required, the system is able to brake the car to a stop then pull away again automatically after being stationary for up to 30 seconds, meaning greater comfort in stop-start traffic. Camera images and data from a front radar system are used for distance control.
2020 BMW ALPINA XB7
Another component of the Driving Assistance Professional Package is the Lane Keeping Assistant with Active Side Collision Protection. This system is designed to help the driver guide the vehicle back onto the correct path with an active turn of the steering wheel. Besides emitting visual warning signals and causing the steering wheel to vibrate, active side collision protection also uses active steering intervention to help avoid a collision. Moreover, this package includes Extended Traffic Jam Assistant for limited access highways, which allows for even more relaxed driving at speeds lower than 40 mph during highly congested highway traffic situations. The Driving Assistance Professional Package includes Evasion Aid, which now also reacts to pedestrians, and Front Cross Traffic Alert – which reduces the danger of a collision when maneuvering forwards towards roads that are obstructed from the driver’s view.
The Parking Assistant Professional package, standard in the ALPINA XB7 enables automatic selection and use of parallel parking spaces. These parking spaces are detected by ultrasonic sensors as the vehicle passes them. The Parking Assistant function is activated at the touch of a button on the center console. The system then takes care of the acceleration, braking, steering and gear changes necessary to maneuver into the space. The included Surround View Camera with 3D View and Active Park Distance Control give you piece of mind when maneuvering your XB7 in tight spaces.
2020 BMW ALPINA XB7
Photos: BMW / ALPINA
Join the 5Series forums now!
