Tire Pressure
My Ride: 545i
Engine: N62
Tire Pressure
I know there are a few threads on this but nothing recent. What tire pressure is generally used on our E60's? What is everyone using and how is it working for you. I have an 04 545i w/sport, Type 124 18's staggered. 245/40/18 & 275/35/18.
I am running F38 / R40psi. Is this too much?
Administrator
https://5series.net/forums/e60-discu...estion-142243/
https://5series.net/forums/e61-touri...winter-140249/
https://5series.net/forums/tires-whe...essure-134246/
The F10 might be different.
https://5series.net/forums/tires-whe...xdrive-133454/
My Ride: 545i
Engine: N62
To my knowledge, the advice hasn't changed. Not sure why you'd regard old threads as inaccurate.
JayArras,
I think you misread my post. I never called the old threads inaccurate, nor did I doubt the validity. I was asking what other members were using in similar setups and what their thoughts were. There seems to be a lot of variation with tire inflation specs. Your links prove that. I am and have been on non-rft setup and wasn't sure if the recommended psi was based on that setup or if it even matters (rft vs. non-rft).
BigxPx
04-23-2015 10:11 AM
