Aftermarket Wheels and suspensions for Xi
Old 06-29-2015, 01:31 PM
  #881
biz77's Avatar
Originally Posted by Kasmo
Can someone provide a picture of a square set up on 19x8.5? possibly with a 35 offset.
Really would like miro 111 but idk how the 35 offset is going to look like, most pictures i have found the wheels were super concave with around 20 offset.
Also for bbs LM (style like) wheels, how big is the lip with a 35 offset? I will be lowering my car and I was about to buy wheels that are 19x8.5 front and 19x9.5 but the rear offset was 30 and front was 35. People where saying i might have to roll my fenders which I dont want to do.
The Miro 111 in 8.5" with mid-30's offset is not very concave. The 9.5" with mid-30's offset looks pretty good. There are lots of pictures on the E90 boards of the Miro 111's with these offsets. If you want truly deep concave or big lip, there really is no option besides going wide with a low offset. If you were to switch over to the standard 535i RWD brakes or M5 brakes and the required parts in the rear (fronts are a direct bolt-on) you can easily run a 9.5" wide wheel with an ET20, but rolling your fenders would be less expensive and easier.
Old 06-29-2015, 03:50 PM
  #882
Kasmo's Avatar
My Ride: 2006 BMW 525ix (N52 Engine)
Ah ok, I mean the other post that i posted in the other thread, the rear wheels are ET 22. It was hidden haha, but anyway, Those wheels are 18x9.5 and are fine with the tires I got everything sits nicely and evenly. Ill post more pictures later.
Looks like my only other option is a wheel design with a lip then or maybe i can accept rolling the fenders after i think about it more. I plan to drop the car too. If not Ill stick with a similar set up i got now, just different wheels.
Old 07-03-2015, 07:31 AM
  #883
E60wagon's Avatar
My Ride: 2008 535xi wagon
Does any one have a list of what stock Bmw wheels with model numbers work without an issue on 2008 535xi wagon .. Preferably 19's. Thinking of upgrading my stock wheels .. Don't minding runny spacers or even getting my fended rolled .. Thanks
Old 07-04-2015, 04:40 AM
  #884
Lugnut2683's Avatar
My Ride: 535xi
Engine: N54
These are all the stock wheels for the E60 (not specifically the E61):
All BMW wheel styles 5 E60+ | BmwStyleWheels.com
It will at least give you an idea of what's out there.
Old 07-06-2015, 07:50 PM
  #885
rayray1558's Avatar
My Ride: 2008 535 xi sport package ,cold weather,navigation etc..
Default new wheels
So I'm getting rims
19x8.5 ET32 FRONT
19x10 ET38 REAR
TIRES
245/45/19 Front
275/35/19 REAR
My question is will this tire set up work fine as far as being close in rolling diameter not to throw the spedo off I've tried the tire calculator guide and can't get it to work! Need some input or suggestions?
Old 07-07-2015, 02:53 PM
  #886
biz77's Avatar
Originally Posted by rayray1558
So I'm getting rims
19x8.5 ET32 FRONT
19x10 ET38 REAR
TIRES
245/45/19 Front
275/35/19 REAR
Those sizes will NOT work on an Xi/XDrive car. The difference needs to be 1% or less.
There is a calculator right at the top of the forum: https://5series.net/forums/tire_rim_calculator.php
Put in your two tire sizes and it will spit out the percentage difference between them. If it comes up more than + or - 1%, then that combination of tires will not work.
The most common staggered sizing for an AWD E60 is:
275/30/19 with a 245/35/19
An even closer match is
285/30/19 with a 245/35/19
Old 07-07-2015, 06:19 PM
  #887
rayray1558's Avatar
The most common offset sizing for an AWD E60 is:
Thanks so much for your help
Old 07-08-2015, 04:20 PM
  #888
Kasmo's Avatar
I went outside the box a bit. I bought a set of wheels 2 days ago, next morning the store called me telling me i will need spacers, So i got those spacers that they said I would need. Regardless, My car is going to be a test subject I feel like.
Wheel specs are:
19x8.5 front 35 offset
19x9.5 rear 30 offset (super close)
I dont know much about wheels and i read up a lot about the Xi and wheels. Decided to go for it anyways. My dad said he would buy the wheels off me if i dont like how they would sit etc. If i end up rolling or pulling my fenders then might as well. The person from the shop told me that the wheels are going to sit flush with the car.
My current set up is
18x9 front 33 offset
18x9.5 rear 22 offset
No problems at all. Car looks good.
Old 07-08-2015, 04:37 PM
  #889
norsecarnut's Avatar
My Ride: 2008 535xiT6
Wheel specs are:
I don't know much about wheels and i read up a lot about the Xi and wheels. Decided to go for it anyways. My dad said he would buy the wheels off me if i dont like how they would sit etc. If i end up rolling or pulling my fenders then might as well. The person from the shop told me that the wheels are going to sit flush with the car.
Spacers may push the wheels out too far. They don't know what they're talking about. The inner clearance is fine. They probably think xi is no different from rwd offset. At most I could see a 5mm spacer on that wheel but it also depends on your suspension height and tire shape. You should try just the wheels first, measure, flex it a bit, then choose spacer thickness.
Old 07-08-2015, 05:04 PM
  #890
Kasmo's Avatar
I already ordered the spacers, and I thought about that about 1 hour after I already put in the order. They said the wheels would hit the strut. We will see. If anything Ill keep or sell the spacers or if possible return them.
I figured Id listen to he guy lol. He is a wheel expert. But then again, I could be one too. lol
Once he said ill need 20mm in the front and 10mm in the rear I was puzzled. My dad said to order the spacers anyway. So listening to my dad and the "wheel expert" i bought em. They had my car model and make and everything. It even said AWD E60 in the list specifically. We will see, ill let you guys know, at least if anything someone will learn from my mistake (if i made one).
Im on stock ride height, still trying to decide if i should lower my car. I want to but i cant afford KW coilovers. And I got 1 more semester left of college before i graduate and well... i need to start saving for some other things. But still want to lower my car...lol...still thinking if i should get those H&R springs (iv read upon hours about them on the Xi models).
Quick Reply: Aftermarket Wheels and suspensions for Xi
