Aftermarket Wheels and suspensions for Xi
Old 10-24-2014, 12:11 AM
  #841
rmayrap's Avatar
My Ride: '09 535xi M Sport
20x8.5 et35
20x10 et40
245/35/20f
275/30/20r
Looks like there's a little more room in there to push them out. I will experiment with spacers and see.
Stock suspension for now.
Old 11-09-2014, 10:11 AM
  #842
Bayerisch Reisenden's Avatar
My Ride: F10 535i
Model Year: 2014
Engine: N55
Hello I lowered my e60 530xd
I installed Bilstein B8 and H&R springs 35mm.
But since I have installed theme I hear a noise on front left side when I take a Sharp right at high speed like "tok tok tok tok"
When I turn left there is nothing.
I hope it is not the front left drive shaft
Have you any ideas ?
some pics
Old 11-09-2014, 12:15 PM
  #843
rmayrap's Avatar
looks good, hows the ride?
Old 11-09-2014, 12:18 PM
  #844
rmayrap's Avatar
added 10mm spacers in rear and 5mm in front. still on stock suspension.
new specs with spacers:
20x8.5 et30 front
20x10 et30 rear
245/35/20 front
275/30/20 rear
Old 11-10-2014, 12:22 AM
  #845
My Ride: F10 535i
Model Year: 2014
Engine: N55
very good handling, but I've these "knock knock knock knock knock knock " on the front left side when I take a right turn at very high speed...
I hope is not the front left CV schaft which does not appreciate the lowered springs....
Old 11-19-2014, 10:59 AM
  #846
BrandonSS's Avatar
My Ride: Alpine White 550i M Sport
Sounds like a cv joint exposed by the recent lowering or a possible wheel bearing issue.
Old 11-19-2014, 11:34 AM
  #847
corey's Avatar
My Ride: Car
I had the B8 & H&R setup before I went KW and had the same issue from the left front, except I also had it on extremely low speed right turns (like when you turn into a parking spot) in addition to the high speed right turning (exit ramps for example). Turned out to be a washer from the OEM setup that the installer used on the B8's. I can't say thats your issue, but the knocking seems similar.
Old 11-19-2014, 12:17 PM
  #848
My Ride: F10 535i
Model Year: 2014
Engine: N55
problem resolved !!!!
it was a very little thing which triggers that sound...
it was the metal serflex which maintains the CV joint which touched the sway bar
I replaced it by a flat serflex and now no sound anymore
Old 12-23-2014, 03:04 AM
  #849
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Will this setup work in my 535xi 08 ?
Miro 111
19x8.5 "F" & 19x9.5 "R"
5x120
35mm "F" 33 "R"
Will my ride quality be as good as running on oem wheels?
Old 12-27-2014, 06:41 PM
  #850
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
If anyone can confirm this for me.. for my stock wheels on my 2008 I want to throw on some 12mm spacers on the rear wheels to push it out a bit more. Looks like there's TONS of space to do it.. but I'm not sure.
I'm curious because if people say I can't fit some Miro 19" wheels with rwd offset (23 I think?) If stock are ET 43? Then it should be "close to ET 31 which I saw in the first few posts that it would be close to limit.
Help? I'll have to dig through the threads again.. I really like the Miros and I would like to stagger the tires slightly for a more complete look. I'm not going to buy until close to spring so I have time. The other idea is to get matching wheel offsets and keeping the spacers so I Can fill the rear fender out a bit nicer.
Quick Reply: Aftermarket Wheels and suspensions for Xi
