E61 Lowering/Firming Up with self -levelling.
Old 04-09-2010, 01:14 PM
Kuul4's Avatar
My Ride: E61 535d
Originally Posted by Spartan335i
This is what some were talking about!!!
I asked Nels996 if the H&R cames with the rear brackets and do not!
Interesting!
I bought -35mm. H&R's and mine also came without those brackets.
Old 04-15-2010, 01:05 AM
norwegianE61's Avatar
hartge does come without them now aswell appearantly. THey seem to have discontinued them.They are very easy to make yourself though, using a set of rose joints...
Old 05-24-2010, 04:59 AM
Vule's Avatar
My Ride: E60 535d M e61 530d Iron Horse Sunday :-)
I'm about to drop the front end -30mm. How low should be the rear end? also -30mm less?
Old 06-10-2010, 06:21 PM
Tiago's Avatar
My Ride: 535d
Model Year: E61 2006
To lower the rear just unscrew the bracket in the black box (sensor), rotate it unclockwise a bit and screw it again. To drop a bit more make sure that the pin of the bracket is off the sensor hole. Hard to explain but once you see it, is quite easy to understand.
Some Tips:
1. Few changes makes big difference in height
2. It is air suspension so it will have the same confort at all heights. Once is the amount of air in the bags that will set the height, ridding it too low will make to hit the bottom end of the suspension at the slightest bounce.
Old 09-19-2016, 11:57 AM
quattromeister's Avatar
My Ride: 535xi wagon
Engine: N54
Originally Posted by Nels996
Maybe I can share my experience with lowering my E61. I used a set of H&R front springs
-35mm. I reprogrammed the rear suspension to match the ride height in the front. The first thing I noticed is the rear is slightly stiffer, and the compression rate was reduced.
Hope I helped.
I am in the same situation, my rear is also 3/4 higher. I am running bilstien sport with H&R sport springs.
I hear of two methods links to trick the rear or reprogramming.
Concern with programming is what if I put weight in the rear? Will passengers have a rough ride? Or will it be fine?
Thanks
Old 09-20-2016, 04:27 AM
pocholin's Avatar
My Ride: 2010, E61, 535i xDrive
Model Year: 2010
Regardless of how you lower it, riders will have a less comfortable ride because suspension travel length has been reduced. You won't feel it too much over small bumps, but you will over large humps and roads that have quick ups and downs (I don't know how to call them, but in spanish are "vados".
Old 09-24-2016, 09:04 AM
Engine: N54
The images the Tiago posted I am not able to see. Does anyone know where to get links or have a link to where some pictures are of ones used for the E61? I would like to level the car out, thanks
Old 09-24-2016, 12:00 PM
pocholin's Avatar
Model Year: 2010
Check this out, this should help.
https://5series.net/forums/e61-touri...owering-98941/
Old 09-25-2016, 08:54 PM
Engine: N54
Originally Posted by pocholin
THANK YOU!!!! This is exactly what I was looking for.
Old 09-26-2016, 05:49 PM
Engine: N54
Does anyone know of a vendor where I can purchase the rear suspension links for a E61 with air suspension ?
Quick Reply: E61 Lowering/Firming Up with self -levelling.
