E60/E61 ix tension strut ball joint replacement?
Old 02-08-2016, 05:57 AM
95m3ltw's Avatar
My Ride: 535ixT
Originally Posted by L337E60
Any luck? I've replaced the control arms yesterday on my 07 530xi and the drivers ball joint stud was moving freely. I have a vibration when I brake at 65mph+ and it is not the rotors. So I think I will replace the ball joints next.
This thread is showing how to remove the ball joint on an 06 530xi, in case you need it:
Stuck Ball Joint? - Bimmerfest - BMW Forums
Good luck.
Next time I have the car on the lift, will try that method. But there have been many in my research that experienced the ball joint pulling out of its housing, leaving the housing still stuck in the hub. They were using a slide hammer to pull the ball joint down, so I expect the method above might be "more" gentle vs the hammering and less likely to pull the ball joint apart. Will probably attempt it again in a week or so, will report back if I do.
yakev724
05-02-2016 09:46 AM
heple
12-01-2015 12:53 AM
yakev724
DIY: Do It Yourself
11-24-2015 11:56 AM
Notheld
11-22-2015 10:19 AM
ifarted
11-14-2015 12:14 PM
Quick Reply: E60/E61 ix tension strut ball joint replacement?
