Coilover Roll Call - KW - FK - JRZ - ISC - Lets hear your Review!
Old 05-03-2016, 09:25 AM
  #121
brnmcn's Avatar
My Ride: '08 E61
Originally Posted by Alpine003
Sweet ride. What are your spec on your wheel/tire setup?
Are those genuine m5 fenders/bumper?
Been wanting to do the rep m5 fenders but not totally clear if they are as wide or just have the grills for looks only.
Metal and polypropylene reps.
19x9.5 +22 on 245/40, 19x10.5 +22 on 265/35
Rear fenders rolled only.
Camber for stance and no rubbing, if you're about that life.
Old 05-03-2016, 12:16 PM
  #122
Alpine003's Avatar
My Ride: e30
Thanks, can you tell me which metal M5 rep fenders you got and if it's the same width as the factory M5 fenders? Does the Poly M5 front bumper rep work with the wider m5 rep fenders?
Any other shots?
Old 05-03-2016, 12:37 PM
  #123
brnmcn's Avatar
My Ride: '08 E61
Any other shots?
Some shit on eBay for less than 350. All over the place...stock body width.
I know that someone forced an M-Tech front to fit the real OEM wide M5 fenders...also need new inner liners for the real M5 Fenders.
Old 05-03-2016, 01:05 PM
  #124
Alpine003's Avatar
My Ride: e30
So you fit 19x9.5 +22et with 40 series tires on narrow body front fenders? Sorry, just trying to figure out how you managed to do it as I would think it would rub.
Old 05-03-2016, 01:16 PM
  #125
brnmcn's Avatar
My Ride: '08 E61
Yes. Increased negative camber for clearance, no rubbing, and tendency for oversteer under spirited driving.
I wouldn't recommend this for most people.
The ISC's have camber adjustments up top and the spring rate can be built to your specs.
Shout out to ISC for a spectacularly made coilover!!
Old 05-04-2016, 12:48 AM
  #126
timmay77's Avatar
My Ride: E39 M5
Model Year: 2003
STANCE. He has to be running 2+ degrees of camber. Wow....... I bet he CHEWS through tires.
Old 05-04-2016, 07:24 AM
  #127
brnmcn's Avatar
My Ride: '08 E61
Negative camber, in case someone wants to ask.
True; I chew through tires...as do most people who use a car. I've aligned the toe correctly to increase their life.
Old 05-04-2016, 12:53 PM
  #128
MiniNL's Avatar
My Ride: 2008 BMW 535XiT Sport Wagon
Stock rears are close to -2 as well, if I'm not mistaken, although they generally have an easier life than the fronts.
Old 02-08-2017, 10:47 AM
  #129
Ledd Dewey Lemmenes's Avatar
My Ride: e61
any experience with fortune auto 500 coilovers? just spoke with them and i was told they will make E61 XI coils
Old 05-27-2017, 06:01 AM
  #130
Triet Nguyen's Avatar
My Ride: e61
I had terrible experience with my ISC. I was an early buyer on the coilovers.
The rears was stiff so I went back to stock. The fronts creak and bottom out all the time.
Did ISC redo their suspension!? really love my E61 for a daily might just get KW V3 but they are so damn expensive!
Quick Reply: Coilover Roll Call - KW - FK - JRZ - ISC - Lets hear your Review!
