Sprint Booster Install
Old 08-12-2015, 02:20 PM
marco211's Avatar
My Ride: 545i
Default Sprint Booster Install
After trying to find the best place to route the booster since behind the pedal was not possibly and I didn't want it visible off to the side.I decided to hide it behind the carpet. I cut the carpet 1" above the pedal bracket and pulled the carpet forward and ran it through the back. Booster not visible at all love the end result . Better throttle response
Attached Thumbnails Sprint Booster Install-picture-004.jpg   Sprint Booster Install-picture-005.jpg   Sprint Booster Install-picture-008.jpg
Old 08-12-2015, 10:26 PM
Tsoup's Avatar
My Ride: 13 X5 35i M-Sport (Sold) 535i M-Sport - (Sold) 07 530i Sport Gray - (Traded) 04 530i Sport Gray
I didn't have to make any cuts to my install...yes a bit tight back their but it fit!! Plus I decided to leave it in "hot rod" position and loose the dongle changing cable!! :-0
Old 08-20-2015, 09:29 AM
kcrokin's Avatar
My Ride: 550i M Sport
I was thinking about getting one, is it worth it. Since you more low end do you loose pick up as you continue to accelerate?
Old 08-25-2015, 03:26 PM
marco211's Avatar
My Ride: 545i
Default Booster
The booster just increases throttle response from the pedal to the engine . Responsive through all RPM bands. I love it makes car fun again . I just had to get use to backing up on a hill LOL , I was burning out haha. I would recommend any one to get it.
Old 08-25-2015, 06:54 PM
kcrokin's Avatar
haha I will have to get one, I have heard people say that it does not make ur car faster but how does it not if: your throttle response is increased therefore you move "sooner" how do you not reach 0-60 faster?
Old 08-26-2015, 05:51 PM
seven11's Avatar
My Ride: 535
how would throttle response increase your acceleration?
when u press the gas pedal 70% the sprint booster makes the car think u pressed it 100% (not sure about the actual values just making an example)
u can do the same without a sprint booster and just floor the gas pedal 100%
Old 08-26-2015, 06:56 PM
kcrokin's Avatar
haha I got it now
Old 09-13-2015, 06:04 PM
Tsoup's Avatar
haha I got it now
still drives 100% BETTER w/the booster...
Old 09-14-2015, 11:41 AM
kcrokin's Avatar
so if you keep in the "hot rod" or high performance position does it consume gas much faster?
Old 09-17-2015, 04:46 PM
Tsoup's Avatar
1. common sense, 2. any car will do the same (spirited driving), and (3) I think I admitted that waaay early on if not in this post on another but "I" am okay w/it. Prior to install, I was getting 20-23 mpg and now I'm getting 19-21 mpg...which is still decent numbers...
enough analyzing and talkin...put on some Jordan's and JUST DO IT!!!
Quick Reply: Sprint Booster Install
