Sportautomatic (SAT) retrofit
Old 07-03-2016, 11:22 PM
  #831
mcbonio's Avatar
My Ride: 530d Sport LCI
First dibs on the SAT shifter!!!
How much for the shifter???
PM me please!
Old 07-03-2016, 11:34 PM
  #832
likhan_s's Avatar
My Ride: 530e Alpine White
Model Year: 2017
PM me please!
@mcbonio: Thanks for the interest, but I would prefer to sell all of this together. However, if that does not work out, you will the be the first for the shifter.
Old 07-04-2016, 06:10 AM
  #833
mcbonio's Avatar
PM me the price for the whole kit then Likhan.
Old 07-12-2016, 05:56 PM
  #834
08Black535xi's Avatar
My Ride: 2008 Black/Black 535xi
I would like a price on the whole kit also please.
Old 09-27-2016, 05:29 AM
  #835
m5proud's Avatar
My Ride: 530xd e61 '07
Hi fellas!
I have retrofitted SAT shifter (only, no paddles) to my 530D 2008.
I deleted $205 and added $2TB to VO, wrote it to CAS and LMA.
Then I replaced firmware in my EGS (GKE195) to 7592130.
Then I coded with new VO KOMBI, EGS, GSW and few other ECUs.
I changed PADDLES in EGS to value_00.
But it still not working. Sport button works, I can shift gears (and it goes much faster with this firmware), but I can't switch on Parking, and there are no LEDs on shifter.
What have I done wrong?
Old 10-02-2016, 06:43 AM
  #836
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Originally Posted by m5proud
Hi fellas!
Where did you find your ZB# for your car?
I'm trying to do it on my 535d 2008
Old 10-02-2016, 11:51 AM
  #837
leew88's Avatar
My Ride: E60 530i LCI N53
Hi fellas!
You've done everything correctly as when I did my SAT conversion, ZB is correct according to my sheet, it sounds like your SAT shifter ECU (beneath the gearshift) is either faulty or bad connection.
Old 10-02-2016, 11:54 AM
  #838
leew88's Avatar
2TB ZB for euro 535d with M57N2 engine is 7592134
Old 10-03-2016, 05:15 PM
  #839
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
I look my car info up and engine is M57Y will it be the same ZB?
Old 10-04-2016, 11:32 AM
  #840
leew88's Avatar
If your transmission software is GKE195 family then yes. Some models are under GKE215 in which case you need to verify by checking it in INPA, NCSEXPERT etc. and then look up the 2TB ZB on the associated .ATS file.
You signature says 535XI, so you are talking about doing it on a 535D?
Quick Reply: Sportautomatic (SAT) retrofit
