Self made ram air
Old 10-09-2012, 11:36 AM
  #41
bighead2267's Avatar
that's an impressive improvement. about the video you recently post. it will be more convincing if there is before and after the tube is install.
also, mind me asking the diameter of the tube?? thank you
Old 10-09-2012, 02:42 PM
  #42
545IblupasdU's Avatar
True, I didnt think of doing any test when there was nothing there, especially since it was pretty much an experiment that i didnt think I could get to work.The entrance to the airbox is off to the side pretty much right behind the headlight......any air going into the kidney is going straight back to the radiator no air can be rammed into the box without something like the pipe guiding it. But yea It would be a more complete test showing the before result with nothing passing through.
The diameter of the pipe is 3".....what I had lying around....wonder if I should do one with 4 inch?
Old 10-09-2012, 02:54 PM
  #43
i guess it's time to Home depot shopping.
Old 06-15-2013, 02:32 PM
  #44
Seanaabrown's Avatar
Default size
hey, id like to do the same thing
how big is the pipe size,
what is the diameter size please
Old 06-17-2013, 08:35 AM
  #45
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Originally Posted by 545IblupasdU
Well I got some more results just As a note I was carrying 130 lbs more in the car, tires pressure was the same, I ended with 27.6 mpg arriving at my destination, that is .6 better even with the 130 increase in weight....I'm sure if I had the same weight in the car I'd been above 28mpg the computer has adapted to the increased airflow! So my first 650 mile trip gave me 27mpg and even with an increase in weight I still gained another .6 over the original 27 mpg I'm very happy with the functionality of my ram air.
So I'm gonna estimate 3mpg increase from 25.3 to over 28!
I am afraid that your estimate is not based on results which would be considered statistically signiifcant. You need much more before and after data to establish if the difference in mileage is really significant and not just due to normal variability. The difference in air pressure at the inlet of your air collecter is probably not more than if the barometric pressure had changed that day.
Any small benefit that you might have gained, would be negated by the small decrease in overall coefficient of friction due to the modification of the air intake. IOW, you increase the drag by 'collecting and raming in' more air.
Respectfully, Bob P.
Old 07-21-2016, 02:05 PM
  #46
If thats the case then everyone who has purchased the RPI ram air which is basically a shovel that doesnt guide or force any air into the intake box have been robbed! At the very least my ram air is a true ram air. And with over 2000 highway miles of testing after the installation my fuell economy went up. by 3+ miles per gallon. Those are my results! The same air that was going to hit the radiator went into the pipe.......its not like I collected some extra air from another area to change the drag. I would think that air that is getting sucked into the engine has less drag than air hitting the flat surface of a radiator blocked off from behind by mechanicals.
Old 07-21-2016, 07:55 PM
  #47
Model Year: 2005
Engine: N62
If thats the case then everyone who has purchased the RPI ram air which is basically a shovel that doesnt guide or force any air into the intake box have been robbed! That is correct, those devices are useless, just like "cold air boxes"..
By Increasing the pressure at the inlet of your ram device, you are simply reducing the air pumping loss of the engine slightly, not introducing more air. The very slight air pumping loss difference is not worth almost a 10% increase in mileage. At any rate, if more air is introduced, the computer adjusts the fuel accordingly and then modulates the engine speed to give the speed that you want, i,e, the same horsepower is produced to give you the same speed, albeit at a very slight loss in air pumping loss. Even then, the extra length of pipe introduced will reduce the pressure back to the original pressure at the original inlet at the filter box, hence , no gain.
Also, the only proper way to calculate mileage is to use fuel consumed with miles traveled. The on board computer has too much variability and lack of repeatability to be used as a statistical tool. Unless you calculated your mileage properly before and after the change, then I find your claims suspect.
Respectfully,
Bob P.
umichchris
12-07-2015 03:33 PM
bifajv
07-30-2015 05:37 PM
PelicanParts.com
07-23-2015 12:41 PM
SayeedA
07-16-2015 06:57 PM
kentuckynet
F10 Discussion
07-03-2015 06:14 PM
Quick Reply: Self made ram air
