PT-CAN (E61) on BMW530 Touring
My Ride: BMW 530xi
Hi.
I just wrote another post, sorry the double but there are some changes as I found interesting docs. I will now try to delete the old post.
I am trying to read the PT can bus (500kbps, wires red and blue/red) of a BMW 530xi (E61).
I use an Arduino, a can-shield interface and a "crocodile" to read the can signals without cutting the wires. I can already read well the K-can bus (100kbps, wires yellow and black) with this system , so I am sure everything is working perfectly.
Under the hood I found a bunch of wires. According to docs colors must be RED and BLUE/RED. I checked a RED-BLUE/RED twisted pair and I can see only a pulse (every 750ms, the pulse is 0,5 ms long).
Now I just read that there is an extra wire (KL_15) to wake up, and the 3 wires all all together into a "ribbon" cable. That means I am looking at the wrong wires...
Can somebody tell me HOW are they made?
I need an easy place where to place the "crocodile" and read the PT can bus.
Thanx
Thanx
Engine: N54
Those are pretty easy to find in the wire harness under/behind the glove box. There is a junction box where many of the computer module plug interfaces are.
My Ride: BMW 530xi
Found, NoQuarter. Thank you!
It is BELOW the fuses, not BEHIND.
From the image of connector X13581 I found in BMW Online Wiring Diagram System (WDS) by BMW-Planet.net I wrongly assumed I needed to remove the fuses harness. From another doc I understood I need to remove the glove box instead: it is covering the connectors.
Engine: N54
So.... Whatcha making? If it requires PT-Can it must be something interesting!
My Ride: BMW 530xi
I already did it learning from the scratch on a VW Caddy and it was even too easy to extract something nice. I am using Arduino with canbus shield, a crocodile to read the cables, some Python code to read and save the data sequence. I also bought a chinese bluetooth interface and I am learning how to write android code to play with it.
I would like to read out realtime data about RPM, ABS, torque, pedals, and so on and I assume they are in the PT-can.
Just because they are there, so why not?
I believe it has to do with mountaineering: "I climbed the Everest because it was there"
My Ride: 2006 525i
Model Year: 206
Hi
Since you worked with Can wires, do you know how to best tap into a CAN wire? I am retrofitting PDC to mine and i cant find any connector with spare pins. Thebonly way seems to be tapping into exisiting Can wires. I read somewhere that soldering and heat tube are not recommended.
My Ride: BMW 530xi
Richie, I am using a can "crocodile": CANbus readers | Wagencontrol: fuel monitoring for GPS tracking systems
It works perfectly and is very sensitive. The only problem is the size of the sensor: being normally can bus twisted pair, you need to "untwist" at least 4 cm. In a car, where cables are short and usually packed together, it can be a little difficult. But it works.
I already used can bus in other applications. It would be possible to add a couple of wires to a connector to read easily a can bus signal on an Arduino Can Shield, but there is a problem with line resistance. It is possible that adding a device the R changes and some smart device signals it as an error...
Engine: N54
I'm not so sure guys. The whole point of a canbus network is to add devices to the network. Certainly there is a length and device limit but nothing to be concerned about here I think.
Just be careful keeping twisted pairs twisted and make good quality connections.
My canbus project not only just listened to the traffic but also communicated back. I used the steering wheel buttons to run a "preferences" routine that put everything where I wanted it for "sport mode" for example.
My Ride: 2006 525i
Model Year: 206
So would it be ok if I just solder a new twisted pair of canbus wires to add in my PDC? I plan to connect it to the passenger seat's one.
@NoQuarter
@NoQuarter
My Ride: BMW 530xi
More legend than science.
On the other side I want only read, not write on the bus. I would not like to send the wrong command and explode the airbags during my game...
