Need help finding correct fuse box connector terminal
Old 08-05-2016, 05:56 AM
John E's Avatar
My Ride: E60 520i 2004
Question Need help finding correct fuse box connector terminal
Hi people,
I'm currently trying to install a 12v socket in the boot of my E60 (08-2004), but ran into a small hickup.
Before I started, I was informed to add the plus wire to pin 9 of the fuse box connector for power using fuse 82. After opening up said connector, I see pin 9 is already in use. There's a red wire with dark blue stripe installed.
Should I use a different pin all together? Should I solder my plus wire to the red/blue one?
What's red/blue normally used for?
Thanks for any info!
John
Attached Thumbnails Need help finding correct fuse box connector terminal-image.jpeg
Old 08-06-2016, 03:24 AM
John E's Avatar
Never mind. Everything is done. Turns out I was looking at the wrong connector. ☺️
CHRGRS_BMW
38
09-01-2016 09:39 AM
e60gg
09-04-2015 10:56 AM
PelicanParts.com
08-14-2015 10:15 AM
ZeZe
10-15-2003 12:58 PM
Quick Reply: Need help finding correct fuse box connector terminal
