looking for retrofit inspiration
It depends on what color you want, but for the black ones, the part number is 63319242154. You also need the LED-module with finished cables, part number 61319242163. I made Y-split cable so i didnīt have to cut in the cars wiring. I took the ambient light wires from the rear doors, connected them to my Y-split cable and wired it back to the door. Plug and play sollution.
thx u
Engine: N54
My Ride: 2004 BMW E60 525dA - Comf. seat, Hi-Fi Logic7, Navi prof, carphone prof, seat ventilation, Dynamic Drive, Active steering ++ Retrofits:- 9x20 & 10x20 BMW Style 101 w/ 255/30 ZR20 and 305/25 ZR20- 35/35 H&R sport springs - M-sport package- M5 trunk li
Ok, i can make for you if you want, but i will guess you can do this by your self, since you need to take out two wirings from your door and connect it to the Y-split, and then connect the Y-split to the door again.
No, you donīt need to remove the door panel. You just need to remove the lower B-pillar cover and the upper cover where you have to drill holes off course. To connect to the ambient lights, you just take out the door connectors and make the split here.
Engine: N54
Thanks.
Youīre welcome! Here is another retrofit you may find interesting.
Comfortseat headrest for rear seat passengers.
omg...were do u get your parts?
i am looking for a full options m5 build before 9/2005 mirrors with 3 connectors
and i want those head rest in auburn color
tell me what is your email paypal to get all the parts for me
thank you!
thank you!
I buy mainly from retailers, eBay and similar. The headrests in the back seat were purchased used on eBay, and modified with the original headrests from a wrecked car. You cant use the as they are, since the rods are thicker and without no traces for heigh adjustment. I can see if i find some pics from the operation.
Unfortunately I only had this picture, but it say that there is little that needs to be dismantled.
jluzbet
11-07-2015 01:25 PM
