looking for remote Codder to unlock some goodies
Old 04-08-2015, 03:40 PM
biz77's Avatar
Have you tried basic coding with NCS Expert? Is that working?
Old 04-08-2015, 03:57 PM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
I have not yet. .was interested in the tcu flash mainly. .coding is the extra icing..but not that important to me.
Old 04-08-2015, 04:08 PM
biz77's Avatar
I would see if you can do basic coding through NCS Expert:
  • Open Coding Tool
  • Open NCSExpert
  • FileàLoad Profile – load Expertmodus (Offen) profile
  • Click “OK”
  • Click F1: “VIN/ZCS/FA”
  • Click F3: “ZCS/FA | ECU”
  • Select chassis (E60)
  • Click “OK”
  • Choose ECU – select “CAS”
  • Click “OK”
  • You should now have VIN and FA appearing. FA is VO code.
  • Select F6 “BACK”
  • Select F4 “Process ECU”
  • Select module to process from the pop-up
  • Click “OK”
  • Select F4 “Read ECU”
  • Window will pop up with .TRC file. Close it.
  • Go back to coding tool and select “Load TRC-File”
  • You should get a list of all settings available in the module.
  • Use “search” button to find parameter. Click “Search next” until you find the parameter you are looking for.
  • Select parameter value, for example “nicht_aktiv”
  • Pop up box will appear to alter the value. There may be a tick box for a “quick change” from “nicht_aktiv” to “aktiv” for example. In some cases you may have to input the data, “wert_04” for example.
  • Once value is changed, click “OK”
  • Click “Save MAN-File”
  • Click “YES” on pop-up
  • Click “SAVE” on pop-up
  • Click “YES” on pop-up: “Do you want to backup the MAN-File?”
  • Click “SAVE” on popup.
  • Go back to NCSExpert and click F2 “Change Job”
  • Select “SG-Codieren”
  • Click “OK”
  • Click F3 “Execute job”
  • Close coding tool
  • Click “Yes” on popup: “Do you want to empty the MAN-File?”
  • Done!
Old 04-08-2015, 04:24 PM
My Ride: 2008 535xi
Engine: n54
Ok I'll give it a go tomorrow!
Old 04-09-2015, 04:37 AM
rackhacker9275's Avatar
My Ride: 09 535xi Touched by TURNER
Model Year: 2009
Engine: n54
Default Sweet input you guys Thx
Cant wait to get my cable... Thanks for all the input PEEPS..
Old 04-09-2015, 05:15 AM
My Ride: 2008 535xi
Engine: n54
Biz77 it worked like a charm.. I coded the turn off legal disclaimer and it disappeared.
Just to be sure, I coded the auto eject key when start button held down and it worked too!
But... I now don't know the source of my error with the TCU flash..
Old 04-09-2015, 08:13 AM
biz77's Avatar
And I'm afraid I can't be of much more help. I would wait for Ken to get back to you. My only suggestion would be to try updating all of your Daten files to the newest version.
Old 04-09-2015, 09:12 AM
My Ride: 2008 535xi
Engine: n54
Okay just one question about updating the Daten files...
So the instructions I got were to open bmwcoding tools, then update the sp-daten, then update the winpfk. This takes a few minutes, even hangs for a few seconds, but resumes fine.
Do I have to do this every single time before I open the winpfk to try the flash? Although I am pretty sure I did this and still got the error.. it's worth trying it again.
I also tried looking up the error and got a few answers:
1) the voltage of my car battery has to be above 13V .. ie I need to hook it up to a charger. This seems odd since nobody mentions I have to.
2) I need to change the communication settings in winpfk .. which I tried to, no luck, different errors
3) my cable isn't set to latency 1 .. but I have verified this over and over it is still com1 latency 1 every single time I plug it into the same port.
Old 04-09-2015, 09:37 AM
biz77's Avatar
Once you update the daten files, they are updated. No need to do it every time.
I did not use a battery charger or any other type of power supply when I flashed mine.
Have you tried asking on bmwcoding.com?
Old 04-09-2015, 09:45 AM
biz77's Avatar
What daten version are you using by the way?
Quick Reply: looking for remote Codder to unlock some goodies
