Installed M5 OEM reinforcement pull rod
Old Jan 23, 2013 | 11:41 PM
  #71
Tiago's Avatar
My Ride: 535d
Model Year: E61 2006
Originally Posted by olivierfm
Realoem is showing a different part number for the E61M5: 51618042815 and 51618042816 (It does not list the price but adds "+core" under "notes").
It seems they are specific to the E61M5. Now I am really confused... Not sure 51618040051 will fit the E61...
The E61 cars with panoramic roof already has from factory the pull rods nr.7 (#51617147515 and #51617147516).
The E61N M5 uses a different system and it seems that cannot be used in conjuction with the nr.7 pull rods because they will cross below the fuel tanks. To use the M5 pull rods nr. 14 (#51618042815 and #51618042816) you will also need to buy the rear strut bars nr. 21 (#51618042818). The nr.21 will connect the nr.14 below the rear shocks. It also seems that the M5 cannot use the nr.7 pull rods because the M5 exhaust and diff.
The M5 system has more parts but will it improve that much over the pull rods for the cars with panoramic roof, to the point to justify the cost???
Old Jan 23, 2013 | 11:58 PM
  #72
Tiago's Avatar
My Ride: 535d
The pic below clearly shows that M5 diff don´t allow to use the nr.7 pull rods. In this case the nr.21 strut bars (fresh black painted) needed to be modified to clear the supersprint exhaust, which was made for sedans that don't use this bars. Stock exhaust go below the stock straight bar nr.21 (2nd pic).
Below there is a pic of a E61 with panoramic roof and a quad exhaust conversion. As you can see, the nr.7 pull rods won´t fit with the M5 diff.
IMHO, the nr.7 pull rods may offer a better rigidity to the chassis than the combo nr.14 and nr.21.
Old Feb 3, 2013 | 06:23 AM
  #73
Mr.Bill's Avatar
My Ride: 2007 M5, Dinan exhaust and performance chip
Apologize for the question - Does the E60 M% come equipped with these?
Thanks!
Old Mar 16, 2013 | 06:41 PM
  #74
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by Rizbel
I don't feel too comfortable looking at the install pull rods attached to the original exhaust bracket; they sit too low and I'm afraid they may get hit by a higher-than-normal bumps or stuff on the road.I ordered the original M5 BMW OEM 18307836970 Exhaust Bracket/Exhaust Hanger/Parts. I will reinstall the pull rods using the correct bracket. You can see the indentation where the pull rods are screwed on flushed to the bracket; this way they're higher off the ground than the previous setup. I will take pictures of the install.
Update:
Correct parts installed and bolts safety wired.
Attached Thumbnails Installed M5 OEM reinforcement pull rod-2013_0316_162517aaa.jpg   Installed M5 OEM reinforcement pull rod-2013_0316_162524aaa.jpg   Installed M5 OEM reinforcement pull rod-2013_0316_171832aaa.jpg
Old Mar 20, 2013 | 05:01 PM
  #75
olivierfm's Avatar
My Ride: 2008 535xit
Is it the last picture on the right? Do you notice a difference with the bars on?
Old Apr 9, 2014 | 01:47 AM
  #76
stormhammer's Avatar
My Ride: Miata Starion Forester
to bump this, but are the M5 pull bars thicker than the OEM E61's?
Old Feb 21, 2016 | 10:27 AM
  #77
jonone's Avatar
My Ride: E61 530d lci
I have found some cheap e60 m5 pull rods/bars on eBay, so I brought them! .......will they fit a e61 530d?
Old May 3, 2016 | 11:13 AM
  #78
jonone's Avatar
Going to try and revive this thread!
I've got an e61 non sunroof and I've brought the no.7 panoramic bars and no.14 m5 bars from eBay, cheap.
I understand they might not fit together so which do I fit first? Anyone had experience with both? The no.14 bars look easier, looks like I might need to tap some holes for the no.7 bars.
Although I might try and mod/ cut them so they both fit.
socale39
Sep 5, 2023 08:30 AM
Awest91
Sep 17, 2022 11:05 PM
chadillac2000
42
Sep 13, 2017 11:15 AM
Inness13
Jun 15, 2016 12:47 PM
