Installed M5 OEM reinforcement pull rod
Old 05-02-2011, 08:49 PM
  #21
olivierfm's Avatar
My Ride: 2008 535xit
The number "7" bars are on our E61's with the panoramic sunroofs. The bars that Ricky installed are specific to the M5/M6 and they would be in addition to our existing bars. I would think the combination of both types of bars would be a great benefit to providing additional torsional rigidity to the rear section of the car, helping both - cornering and secondary vibrations/chassis flex. If we were to add an additional Ultra Racing bar to the rear most portion of the rear sub frame it would also help as well. Basically you would be looking at a "W" type structural bracing concept to the rear of the car which I would think would add significant rigidity and help the car feel more solid.
Originally Posted by alexio
so, are these bars already ON the e61 with panorama roof? if not, how do you feel they helped Ricky?... is it better cornering or less secondary vibrations/chassis flex?
Old 05-02-2011, 08:50 PM
  #22
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Originally Posted by pinguhk
what is number 7 bars?
From E64 photo.
M6 with #20
650 with #17
That's why I think #20 proivde more stiffness than #17
Old 05-02-2011, 09:09 PM
  #23
mmitev's Avatar
Great observation! The good news is that the E61 M5 has both #17 and #20, so you can fit both to an E61 and maybe also E60.
What about #5 and #7 under the front end? I don't see them on the E64 picture you posted. Are they only for the M6? Should they be visible from underneath the car?
Old 05-02-2011, 09:26 PM
  #24
ricky1329's Avatar
Underneath Photo from E64 650, may be this one. I also looking for that to improve the front part also.
Old 05-02-2011, 10:14 PM
  #25
pinguhk's Avatar
My Ride: Mini Cooper
Attachment 120576
how come you car is so clean.
Old 05-04-2011, 08:57 AM
  #26
cleung's Avatar
So after you installed these were you able to put the plastic shields back on underneath the car.
Old 05-04-2011, 05:46 PM
  #27
pinguhk's Avatar
there is not plastic shields for the rear bars.
Only the front has it.
ricky will look for the front bars to try and fit them on and see how it turns out.
Old 05-04-2011, 06:31 PM
  #28
ricky1329's Avatar
Need to cut out the angle of the plastic shields.
Old 05-09-2011, 12:50 AM
  #29
mmitev's Avatar
Ricky if I enter the pull-rod part nr. on the RealOEM cross-reference, I get a huge list of sedans from 520d up to the M5, implying these pull rods are mounted on all these sedans:
http://www.realoem.com/bmw/partxref....51+&showeur=on
This is weird - can you give an explanation from your research? Have you seen them on another factory E60 apart from the M5?
Maybe they are stock equipment for some "bad road" markets?
Old 05-09-2011, 01:00 AM
  #30
ricky1329's Avatar
These pull rods on list but default M5 model only. I think factory save cost and found no need reinforcement beside M5 machine instead of "bad road" markets. I wonder which country is the "Good road" markets in the world.
Quick Reply: Installed M5 OEM reinforcement pull rod
