Headlight Help in Philly Area
My Ride: E60525i: Logic 7, Premium Package, Cold Weather Package, CIC Retrofit, OEM Nav activation, new controller, Combox, 6FL/6NR , Heated Steering Wheel, 6 Speed STEPTRONIC, Bluetooth, 6 CD Changer, Escort 8500 X50 Hardwired, Remus Exhaust, 35% tint, Alufe
Hey guys I'm in a bit of a bind. I had some HIDs installed into OEM LCI headlights on my 2004 Pre-LCI 525i. They work damn well courtesy of the crew at Motorcepts (bought and installed the HIDs there into some LCI OEM headlights I bought myself). However two weeks the cable going into the left headlight housing to the bulb broke. Then today, the same cable on the right side broke. I can't think of a better word than broke. I'm not sure how it happened, but I now have error messages for both low beams. High beams are fine, angels are fine, tails are fine.
Bottom line: I need to find a place in the Philadelphia area that can help me out with this. Splicing the cable won't work because the broken ends going into the headlamp are too short. Thoughts? I need these headlights working again and can't drive up to Queens any time soon.
Thanks in advance.
Thanks in advance.
Here's a pic.
My Ride: BMW E60 3.0d
Its either malted or its rubbing on something that caused it to cut the wires. If you bought the light from the shop you should defiantly go back and show them the problem. This should be covered by the warranty as the product is supplied and fitted by them.
I too had upgraded to oem lci halogens and fitted xenons and its been working for about 4 months without any issues and they were a cheap xenons too, nothing fancy.
My Ride: 2006 530xi w m5 tech kit, 2007 Mercedes e63 AMG, 2005 ford expedition
Check out theses shops. Vac motorsports. Koz.in palmyra nj And motorwerkes They specialize in BMWs
umnitza
11-03-2015 02:58 PM
ucsbwsr
12
07-27-2015 11:20 AM
