ECU, airbag with gateway module, Part # 65776975686
Old 06-06-2015, 09:13 PM
daMANiack's Avatar
My Ride: BMW E60 530i, Production Date May 2005
Default ECU, airbag with gateway module, Part # 65776975686
HI,
I have a BMW 04/2005 E60 530i and have had the following message displaying for nearly a couple years:
Restraint system faulty!
Function of airbags, belt tensioners
and belt force limiters faulty. etc
I do very little country driving so it was the cost that stopped me getting a new part installed.
I recently had the car serviced and my guy said faulty part is:
65776946388 - ECU, airbag with gateway module
Alternative part #'s seem to be:
part number 65776975686
alternate stock code 65776946388, 65776943089, 65776957029, 65776960383, 5776962703
Been conversing with an eBay seller who provides 2 month warranty and guarantees part is without error and said it's compatible with my E60.
eBay part
I believe the part is located behind the glove box but have been unable to remove to check the part # to determine if it's located there.
My glovebox
It appears to have a plastic clip either side but I can't remove/slide out the existing box.
Please, any suggestions how I can remove it.
Cheerz
Attached Thumbnails ECU, airbag with gateway module, Part # 65776975686-bmw_e60_air_bag_module_65776975686-002-copy.jpg   ECU, airbag with gateway module, Part # 65776975686-ebay_65776946388.jpg
Old 06-07-2015, 04:32 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Looks like you bend those clips outward and pull the box out.
Old 06-07-2015, 10:17 AM
daMANiack's Avatar
Hi,
Thanks for replying, yes, it was a very tight fit, after placing thin cardboard strips to keep clips out, after a bit of wiggling, it started to slide out.
Finished up being the same part # as the guy is listing on eBay, I just need to contact my service guy to see if my part is the faulty one.
Cheerz
Old 07-01-2016, 05:31 AM
tivinps's Avatar
My Ride: 2004 545i
Model Year: E60 2004
Engine: 545i / N62
Originally Posted by daMANiack
Hi,
Cheerz
Hi
Did you end up replacing the part?
Did you need to code it or it was plug and play?
From what I have research from the internet is:
I can be replace modules with used ones, but they need to be reprogram with my VIN.
Has anyone use WinKfp to re-program modules with your car VIN?
Old 07-02-2016, 05:40 AM
sparky's Avatar
My Ride: E60
Originally Posted by tivinps
Hi
It's not a plug and play procedure. As far as i remember when i replaced my gateway module with a used one, but with a newer part number than mine, i had first reprogrammed it using winkfp, then code it with ncsexpert and finally reset airbag satelites using ISTA/D to make it work and get rid off that error each time i turned the car on.
Old 07-02-2016, 06:26 AM
tivinps's Avatar
My Ride: 2004 545i
Engine: 545i / N62
Do you remember the process in WinKfp to edit the VIN?
My indy shop only needs that I I edit the VIN and he can re-sync with all car modules.
Old 07-02-2016, 06:46 AM
sparky's Avatar
My Ride: E60
Unfortunately it was reprogrammed by a workshop for me, really sorry buddy i don't know any of the procedure to help you out with it.
Old 07-03-2016, 04:06 AM
tivinps's Avatar
My Ride: 2004 545i
Engine: 545i / N62
Ok thanks
Stranger12
01-21-2021 06:19 AM
Derm
01-26-2017 07:38 AM
fmusbmw
Bluetooth & Cell Phone Forum
05-14-2004 11:41 PM
fmusbmw
04-11-2004 04:13 PM
08-12-2003 11:41 AM
Quick Reply: ECU, airbag with gateway module, Part # 65776975686
