E61 535d Paddle shift mod.
Old 11-29-2014, 10:01 AM
sanjsanj's Avatar
My Ride: E60 530d
sorry I didn't know where to look in wds for the diagram.
okay, easiest way to check with multimeter - find some spare wire, strip it, insert into the connector, put multimeter on continuity test and one of them should change resistance when the paddle is depressed. Do this for all combinations and write them down and you should figure out what does what and what needs to be swapped around.
Do you have M5 paddles? I don't know if theres a difference between that and the non M car paddles, but you might have a lit up + and - sign so the cable could be for that light.
Old 11-30-2014, 01:58 AM
Mission1979's Avatar
My Ride: BMW 535d Touring
Do you have M5 paddles? I don't know if there's a difference between that and the non M car paddles, but you might have a lit up + and - sign so the cable could be for that light.
Hi there
Car is back together now and I'd rather not keep taking off airbag if I can help it.
Still cannot find the drawing I am after. I'm trying to find the actual connector plug on a drawing somewhere.
I haven't got M5 paddles, the pull push type, no lights.
Perhaps I need to try a different approach,
Old 12-20-2014, 01:41 PM
Originally Posted by Mission1979
Hi there
Right, I've got two wires and a four pin plug from dealer, going to have a go at trying to figure out the wiring for the left hand switch tomorrow. Any last pearls of wisdom before I start?
Thanks.
Old 02-03-2015, 12:37 PM
Default Sorted
Well all sorted now. Much more logical now.
Left now pulls to go down, pushes to go up. The opposite to the right hand side.
All I did was simply swap the blue and white and blue and black wires around. Unclip the pin retainer, push the pin tangs down and pull out. Twenty minute job including some time with a spare plug and two wires with a multi meter checking how switch works.
Old 05-02-2020, 12:15 PM
Probation Members
Jonathon Rosser's Avatar
My Ride: 635 E63
Hi mate,
thanks for this update. I’ve been searching high and low to determine what this 4 wire set up was. I’ve got a 635D and am seeking to do similar. Did you actually ever confirm what the wires were and there function. Obviously I will simply try what you did but curious as the 4th wire?
many thanks
ifarted
DIY: Do It Yourself
03-29-2017 09:27 PM
celtic-craig
04-07-2014 01:37 AM
mbart
09-19-2011 09:37 PM
bitboy
DIY: Do It Yourself
07-29-2010 12:01 PM
itiswhatitis
DIY: Do It Yourself
07-27-2009 09:48 PM
Quick Reply: E61 535d Paddle shift mod.
