e60 LCI (2010) LUX v4 install
Old 11-22-2013, 12:17 PM
tom_il's Avatar
My Ride: BMW 525dA 2007 pre-LCI.
Originally Posted by Bill109
sorry i have to ask a dumb question.. these are for lci xenon only.. so these will not fit lci halogens, correct?
correct. They are different for both type of lamps.
Old 11-27-2013, 06:55 AM
wtlb's Avatar
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior MODs: Orion V2s 3000K H8 Yellow Fogs Matte Black Kidney Grills 20" Miro 111 Hankook V12 Tires H&R Sport Springs Special coding via Simon (dbl flash hazards, digital velocity, etc.) LED Side Markers from Trinity Autosports LED License Plate Lights from Trinity Autosports Carbon Delete BMC Air Filter RPI Scoop RPI GT Exhaust Future MODs: Mtech Kit KW Variant 2 Coilovers CIC Retrofit Upgrade Audio System
Good work my man.
Old 12-01-2013, 03:47 PM
blaze129's Avatar
My Ride: 2008 550i M-Sport
Default LUX v4s will fit in e60 550i
Hi There,
I have an '08 550i and Im running the LUX AE v4s and the ballast does fit. Its super tight and may be a real pain in the ass to remove, but they do fit in there.
Old 12-02-2013, 04:46 PM
sequaz's Avatar
My Ride: 535i xdrive
Model Year: 2014
Pics pics pics...
Old 12-03-2013, 11:46 AM
Kidduce's Avatar
My Ride: 2008 E60 535i
Is like to see some day light please if anyone has them.
Old 05-20-2014, 04:31 AM
pinoy1974's Avatar
My Ride: E60 m5
Default Royal Pain to Install
hey guys - i ordered my Lux v4 from bimmian.com because my original H8 bulb on the driver side blew out. $283 inc shipping 2 day from bimmian.com.
white e60 2008 M5
carbon air filters deleted
AFE dry filters
front bumper reflectors deleted
everything else pretty much stock
i gotta say, the removal of the old bulb is pretty easy, but the ballast on the new H8 is definitely much bigger in the rear. couple that with the fact that the rubber washer is a tad too thick, it makes it much more difficult to twist the new ballast in place/locked.
the passenger side was much easier to access and complete.
the driver side however is a royal pain because access to the dust cover is already compromised by the hood release and all kinds of other wires behind the headlight assembly. removal of the old H8 light was simple, but getting the new Lux bulb, ballast, and control dip switch box in is nearly impossible.
for the driver side, i wound up removing the mounting screws and pulling the headlight assembly forward about 3-4 inches (without completely removing), and this was the ticket. in addition, i had to pull the ballast seal washer back so that the new Lux v4 would twist into place locked. once i jumped through all of these hoops with scraped up knuckles and fingers i had to make sure the light assemble was fastened back aligned with the body, bumper, and hood assemblies.
once done however, i left the setting at default at 12,000k which is towards the most 'BLUE' vs white glow.
LuxAngelEyes ˃˃ LUX H8 Version 4 - Color Adjustable LED Angel Eyes
now that they're installed however, they look great! at night with just the daytime running lights on (headlights off) it is VERY VERY BRIGHT. interesting to note is that the inner rings seem to be just a tad bit brighter than the outer rings. my guess is because of simple proximity to the fiber optics - the light does sit closer to the inner ring.
i will also note that i typically do a TON of research on every mod, and the Lux H8 v4 are the best reviewed. i typically review cost, quality, longevity of product, other bimmaniacs opinion, and most importantly ease of installation (because although i CAN do my own mods, i really dont like to). on a scale from 1-10 on this mod for my model car, i'd say it was about a 5 or 6 simply because of the complexity of the driver's side and space to work with (at least on my M5). i compare this to a front bumper reflector delete which is about a 1-2 in difficulty, or even a side blinker replacement at 1-2 difficulty.
all that being said, i'm very satisfied with the purchase and install - scraped knuckles will heal.
will post daytime and night time pictures soon. also on order are 20" Avant Garde M359s w/ Mich Pilot AS3s - should be in this week.
Old 05-20-2014, 08:12 AM
AKAlius's Avatar
They look good Ron, but interested to see what it will look like less blue.
Old 05-20-2014, 02:24 PM
pinoy1974's Avatar
My Ride: E60 m5
so here are the pix from the daytime:
https://plus.google.com/photos/11588...33431210413358
Old 05-26-2014, 02:14 PM
Lotus99's Avatar
I found LED AE's look even better on our E60's than on the 3 series (I have both and have done the upgrade to them). For some reason, the light distribution between both rings is much better on the 5 series, AND it's way easier to install it than in a 3 series.
They typically recommend taking photos from like 20 feet back, as the light shows better, than when up close. I set my Lux's at one or two settings higher than the lowest / warmest colour, so they just have a hint of blue, as the brightness falls off as you keep going up the Kevlin scale.
Old 05-30-2014, 01:55 AM
E92-Lighting's Avatar
My Ride: Next Gen LEDS
looks pretty dim
socale39
09-05-2023 08:30 AM
Florida2002m3
09-01-2015 11:09 AM
milhouse4u
04-22-2015 04:43 PM
G530
03-11-2015 08:23 PM
ZeZe
10-15-2003 12:58 PM
Quick Reply: e60 LCI (2010) LUX v4 install
