Does anyone have a lowered 295/25/20 rear E60?
Old 06-16-2009, 07:38 AM
tim00001's Avatar
Does anyone have a lowered(with springs) and 295/25/20 in the rear(tires)???? Can you tell me how is the setup?? any rubbing???
I have a 535I lowered with HR springs and now run 245/35/20 in front and 275/30/20 in the rear but having a little problem when going into driveway and some turns. (my offset for rear is +22) At some uneven roads, rear rubs also. I am thinking changing tires to 295/25/20 for rear and 245/30/20 for front. I know that front will run nicely but what about rear?? does anyone know if it will rub??
Old 06-16-2009, 01:51 PM
Kzang's Avatar
Wow I couldn't imagine riding on those tires.. it would almost be like riding on rims itself. hehe.
Old 06-16-2009, 01:58 PM
mrfva's Avatar
My Ride: .
Model Year: .
poleposition and anand_rahim run the 295/25/20 tire size on their E60s.
I could be wrong, but I don't think they're lowered, just OEM sport suspension.
What is the width on your rear wheels?
Old 06-16-2009, 02:33 PM
ctsang1234's Avatar
I have 285/30/20's on the rear and have no problem with rubbing. I have 245/35/20's on front, and in some driveways, I rub a little. (It sounds like it's rubbing in front and not in back) I'm on the standard sport suspension.
Old 06-16-2009, 04:21 PM
tim00001's Avatar
My rear now is 20X9.5
Old 06-16-2009, 04:41 PM
hmuchmo1's Avatar
I just recently got a used 545i so I am not sure about the suspension setup but I have 295/25/20 on the rear and 255/30/20s up front and occasionally I will hit enough of a bump to rub.
But not like a bump or pothole in the road...its more like if you go through an intersection at hwy speed that rises at the middle and then drops away again on other side. But just normal driving around has not been too bad.. And the rubbing has occurred maybe 3 or 4 times in the last month and a half.
I can track down what the prior had done for suspension if you need.. it has the sport package, that much i know.
Old 06-17-2009, 04:47 AM
westside's Avatar
My Ride: 545 SE Auto in Black
i have them on mine no problem here are the uk raods are mash up! lowered on Eibach springs
Does anyone have a lowered 295/25/20 rear E60?-20052009_003_.jpg
Does anyone have a lowered 295/25/20 rear E60?-09052009_001_.jpg
Old 06-17-2009, 06:01 AM
tim00001's Avatar
Thanks for the info. Can you find out what kind of drop you have?? or how low your car is lowered??
Old 06-17-2009, 06:37 AM
tim00001's Avatar
Attachment 82247
Attachment 82248
Hello, thanks for the info and pictures. Your car look very nice. Do you know your offset for the rear?? I believe offset have lot to do rubbing also.
Old 06-17-2009, 06:40 AM
westside's Avatar
hi bro iforged do not stamp the offset on the rims for some reason. I also have a set of Hamann 20" I can check the offset on them for u. The rears are 10.5 * 20 and they also give me no rubbing
Quick Reply: Does anyone have a lowered 295/25/20 rear E60?
